(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
(05-08-2016, 01:08 AM)tllim Wrote:
(05-08-2016, 12:02 AM)lenny.raposo-pine64.pro Wrote: OK folks Mate and XFCE images are ready for download
https://www.pine64.pro/downloads/#Debian-Linux
Check first Post for details
Already update and link up to Pine64 wiki page.
Excellent work as usual Lenny Cool
Ok so have your latest up an running. Is there any steps that need to be taken to optimize video playback?
you can use the mplayer script located in /usr/local/sbin
for videos
as for Kodi as mentioned before it works in windowed mode (simply hit "\" key) and go to settings>video>acceleration and use software render mode.
It did the trick for me to watch streams in SD or at most 720p
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(05-08-2016, 10:28 PM)lenny.raposo-pine64.pro Wrote: you can use the mplayer script located in /usr/local/sbin
for videos
Ty wasnt sure if anything changed and until today I had no way to see video on pine other than over xrdp.
(05-08-2016, 10:04 PM)rahlquist Wrote: Ok so have your latest up an running. Is there any steps that need to be taken to optimize video playback?
Obviously optimization was not the goal. Instead just another silly workaround (disable acceleration to heat up the CPU) instead of fixing the issue so Kodi makes use of Cedrus HW accelerated video decoding.
Excellent work Lenny.
Hello all
Sorry if this has been asked elsewhere but I've not seen it after having a quick look through the thread.
I have an issue where my Ethernet is not picking up a DHCP address from my router. I have the Pine64+ 2GB and I'm using the latest software release.
I've tried three different cables, 2x Cat 6 and 1x Cat 5e, two different routers, Netgear and Zyxel, two different SD cards, Sandisk and Samsung.
The order in which I try to get connected is:
Install Image
Resize fs after first boot
Reboot
Plug in ethernet
The IP that is being assigned is 169.192.32.54 which is an invalid address. I've run ifdown eth0 and ifup eth0 but during the up process it says it cannot find a DHCP address to assign. All of the equipment above works on both my Orange PI PC and my Ordroid C2.
Am I missing something?
try editing the uEnv.txt 's mac address in /boot directory Wink
Cheers Big Grin
(05-10-2016, 01:53 AM)lenny.raposo-pine64.pro Wrote: try editing the uEnv.txt 's mac address in /boot directory Wink
I shall have a look at this when I get home from work. Is there anything I need to set specifically or do I just make one up?
Trying to find the perfect 4k media player - PiDevices.co.uk
you can copy the one listed on your board or perhaps make one up Wink
Cheers Big Grin
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,370 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 19,059 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 4,994 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 15,600 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 158,396 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 7,670 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,098 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,121 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 19,595 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 19,431 05-09-2018, 09:07 PM
Last Post: pfeerick
