My Debian journey on the Pinebook Pro
#31
@as400 Sorry for not making this clear - I have included both consoles in the APPEND line as suggested by @schwarzwieweiss and tried both console=tty0 and console=tty1 for the last console. See also my updated blog article.
Well, maybe I should try to reproduce this with Debian to see whether this is a init-specific issue.
With that being said, there are a number of things which don't work ootb on the PBP in Debian/Devuan that have been tweaked in the various distros. However, I am not sure which of these require patches. For instance:
- changing screen brightness using hotkeys
- battery gauge
(01-06-2021, 08:48 PM)kuleszdl Wrote: With that being said, there are a number of things which don't work ootb on the PBP in Debian/Devuan that have been tweaked in the various distros. However, I am not sure which of these require patches. For instance:
- battery gauge
Regarding screen brightness and the hotkeys: there's three parts to this
  1. An interface to actually change screen brightness, in this case available at /sys/class/backlight/edp-backlight/brightness
  2. The hotkeys being recognized as XF86MonBrightnessUp and XF86MonBrightnessDown (EDIT: defined in /lib/udev/hwdb.d/60-keyboard.hwdb which is part of udev (search for Pinebook Pro in this file))
  3. Some software that will run when you press the hotkeys: brightnessctl, available in Debian
So all that remains should be to configure whatever window manager or desktop environment you are using to actually execute brightnessctl when you press the hotkeys, e.g. I have the following lines in my .config/sway/config:
bindsym XF86MonBrightnessUp exec --no-startup-id brightnessctl --class backlight set 10%+ bindsym XF86MonBrightnessDown exec --no-startup-id brightnessctl --class backlight set 10%-
EDIT for clarification: I'm not saying that brightnessctl is the only way to get this to work nicely. Your desktop environment might include its own tooling and you might just need to enable or configure that. I'm just saying: all the parts required are included in Debian bullseye but you might still need to glue them together.
- battery gauge
Regarding battery gauge: battery information is available at /sys/class/power_supply/cw2015-battery/. For some reason this information is not in the standard path /sys/class/power_supply/BATn/, so you need some way to tell whatever tool you want to use where to find the battery information.
  Boot Order in Pinebook Pro food 12 18,946 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,438 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,191 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,840 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,595 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 123,008 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,737 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,418 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,708 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,308 12-13-2023, 07:22 PM
Last Post: trillobite
