Modem scripts replaced by eg25-manager by apt-get dist-upgrade
Today I ran apt-get update && apt-get dist-upgrade and noticed the following in the output:
Selecting previously unselected package eg25-manager. dpkg: considering removing pinephone-modem-scripts in favour of eg25-manager ... dpkg: yes, will remove pinephone-modem-scripts in favour of eg25-manager Unpacking eg25-manager (0.1.1-1) ... ... Setting up eg25-manager (0.1.1-1) ... Created symlink /etc/systemd/system/multi-user.target.wants/eg25-manager.service → /lib/systemd/system/eg25-manager.service.
Is this something that is supposed to happen? After rebooting the phone, modem exhibited the same behavior as before - after about 20-30 seconds a 3G signal is indicated, about 10 or 15  minutes later it switches over to 4G. A test call worked OK.
Sometimes reading the source code of both can solve a lot of questions.
https://gitlab.com/mobian1/devices/pinep...em-scripts
https://gitlab.com/mobian1/devices/eg25-manager
Looking at the programming/scripting languages used and how the code itself looks like, my guess is that pinephone-modem-scripts was just a simple script to get around the propertary driver, while eg25-manager is the actual open source replacement.
It happens sometimes within the Linux community when there are only propertary drivers for certain hardware, workarounds or official drivers are being shipped until there's an open source version to replace that.
Basically if it's all working fine (or better), then there's nothing really to be worried about.
Edit:
Here's a more accurate answer:
https://forum.pine64.org/showthread.php?tid=12511
母語は日本語ですが、英語も喋れます(ry
Thanks, I figured it was something like that, just wanted to make sure. Since most of what I want to use the Pinephone for is working it's easy to forget that the software is still alpha and likely to experience major changes.
Exclamation Cannot flash the modem firmware anonymous 9 14,118 12-17-2025, 01:42 AM
  Logging modem dialout attempts biketool 2 3,580 04-11-2025, 02:47 AM
Last Post: vusra
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 6,100 02-21-2025, 07:25 AM
Last Post: dragonhospital
  Upgrade to Mobian (Trixie) Staging biketool 13 12,179 12-29-2024, 10:35 AM
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,854 12-01-2024, 07:54 PM
Last Post: dchang0
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,558 09-01-2023, 11:29 AM
Last Post: Mahgue
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 11,340 06-06-2023, 06:36 AM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 7,180 03-01-2023, 04:45 PM
Last Post: anonymous
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,969 02-27-2023, 04:18 PM
Last Post: calinb
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,679 01-04-2023, 06:46 PM
Last Post: 3x5co
