Armbian for the Pinebook Pro [WIP]
#31
awesome. I posted a working usbc to HDMI cable matters part in the wiki.
Hello all,
I tried the Buster image, and it doesn't boot.
I'm using a bootloader from the SPI flash (https://github.com/pcm720/u-boot-build-s...v2020.07-1)
The bootloader appears to happily boot the pre existing Manjaro distribution on the eMMC.
Is it expected that this configuration works?
I've just installed Armbian 20.08.4 Pinebook-Pro 5.8.11 desktop on my Pinebook Pro.
Just wanted to report that I successfully installed the latest Armbian image for the Pinebook Pro.
Easy install. Boot from SD card and installed to eMMC. No issues.
I even got a second display to work with an Anker USB C to HDMI adapter.
Everything works fine and it's very responsive.
Same here.
I am using Armbian for a while now on sd-card with LXQt and it runs very stable.
Also nice is that is receives regular pinebook pro related upgrades.
also the battery status works already?
Seems that battery works (maybe also suspend), trying to install KDE and will see.
I can confirm that battery status work and also suspend to RAM seem to work too. It wakes up with no problem (running from SD card yet)
Also works fine after upgrading to 20.10.
(12-21-2020, 12:21 PM)Wizzard Wrote: I can confirm that battery status work and also suspend to RAM seem to work too. It wakes up with no problem (running from SD card yet)
Glad to know Armbian build's battery status and suspend to RAM works well on Pinebook Pro. Thumbs Up.
No, sorry, s2idle, won't last a day
It does wake up OK though
(this with focal, didn't test older version)
You may also want to try the 5.10.x dev kernel via armbian-config its definitely feels faster to me.  I
Although ive heard diskio hasnt been as good with 5.10 on other devices over pcie.
If you're familiar with the armbian build tool try the new desktop branch.  We have some new desktop options including gnome and mate.
Im hoping to publish some desktop preview images in jan.  Our next scheduled release is february
Rock64, H64, PBP Running Armbian
  Boot Order in Pinebook Pro food 12 18,438 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,248 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,100 08-09-2025, 06:53 AM
Last Post: Sb2024
  Armbian fix, current version now works Sb2024 0 2,876 08-08-2025, 08:49 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,451 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,646 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,328 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,454 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,196 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,411 12-11-2023, 03:47 AM
Last Post: calinb
