PureOS on Pinephone
#81
All,
Long time ago I did some development on the OpenMoko and Casio BE300 Linux port, and last week I received my PinePhone, tried a couple of distro's and decided to take the PureOS route for now.
I successfully build my first image using kernel from Phosh image and injecting it into a Librem 5 image thanks to the instructions from mozzwald.
Next step is to compile my own kernel instead of extracting the one form Phosh, and eventually also building the Librem image myself.
Anyone on here actively working on the PureOS flavor ? Anyone keeping track of the list of issues ?
Cheers,
Filip.
The download server seems to be down - is @clover still working on this port?
Just learned about it due the 13 distro-boot-image and was by far the snappiest of all - would like to dig deeper into this one
I will look into why the download server is down, but i've paused development on this until the bullseye images are in better shape. Buster is too old to keep up with upstream phosh.
@clover Any news?
Hi all,
I am trying to get pureos to boot on my PP64. I followed Mozzwald's instructions at __https://gist.github.com/mozzwald/3104aadf2cc8f567a72b6b7837164f69. All commands seemed to complete with no errors. The changes to his instructions that I made were:
1. For line 14, I used the 20210529-0206-postmarketOS-v21.03-phosh-6-pine64-pinephone.img instead of the pine-pinephone-20200218-phosh.img.xz file that he used.
All other files used were the same as in the instructions.
After flashing the librem5.img to the eMMC on the PP and rebooting, I'm getting a solid red power light and a blank screen. Flashing the librem5.img to a 128GB SD card produces the same result: no boot, blank screen. So, it seems to me there is a problem with the compiled librem5.img file, but I have no idea what it might be. Anybody have any ideas? TIA for any assistance provided.
ssilvi
That guide was created before the 3gb version of the phone. I remember none of the images worked on the 3gb version before some update.
"A newly installed OS does not boot on 3GB PinePhone. U-Boot did not have support for A64 chips with 3GB RAM, and un-patched versions will fail to boot on 3GB (Convergence Package) PinePhones. The patch/commit required is titled: "sunxi: support asymmetric dual rank DRAM on A64/R40" source
(06-11-2021, 06:19 AM)Nooblife Wrote: That guide was created before the 3gb version of the phone. I remember none of the images worked on the 3gb version before some update.
Yes I found that out. The scripts on github by mozzwald and rufferson for creating a PureOS image for the PP do not boot on the 3GB PP 64 model. Does any know how to modify a PureOS image for the PP 3GB? I haven't been able to find anything on the net.
I'll take that as a "no", since nobody has responded. BTW, there are some scripts by rufferson on Github (h t t p s://github.com/rufferson/pureos-pinephone/issues/3) that should compile a PureOS image that WILL boot on the PP64 3GB (I tested this once and was able to boot PureOS successfully). However, I'm unable to successfully reinstall because I don't remember the exact sequence of steps I used the first time.
@ssilvi
Check our forum wiki, there is quite a bit of information there on the Pure OS, including a 'How to' link to mozzwald.com
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(07-30-2021, 08:12 PM)bcnaz Wrote: @ssilvi
The mozzwald script was created for the PP64 2GB model; the build that script creates will NOT boot on the 3GB model. Github contributor 'rufferson' has created some scripts that create a bootable PureOS image for the PP64, which I successfully installed a while back. However, I needed to recreate and install that image but couldn't because I couldn't remember the exact sequence of steps that are required. This is why I was asking if anyone else had been able to boot a PureOS image to the PP64 3GB version.
delta1071
  asterisk or FreePBX on pinephone? vanja 0 994 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,852 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,311 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 249,756 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 236,199 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,488 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,862 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,042 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,317 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,357 07-26-2024, 10:35 PM
