Seemingly lost power permanently now /cry
Exclamation
Hello again Pine64 forums.
The very nice wdt helped me earlier this week on an issue with my Pinebook Pro not powering on here: https://forum.pine64.org/showthread.php?tid=12057
I had Manjaro 20.04 on the eMMC which I got working. I decided to ditro hop over to Ubuntu 18.04 (LXDE) using a microSD card. It worked fine, booted up & I was doing some fairly simple things on it. I decided to run `sudo apt upgrade` on the distro & it wouldn't reboot properly. Deciding I should leave well enough alone I tried to boot back to Manjaro & couldn't. I figured since my mirrors were out of date & I should just reflash the eMMC to Manjaro 20.10 - I did so via Etcher but I couldn't boot; just the red power light at power on. Having run into this & corrected with wdt, I thought it was a uboot issue. I wanted to follow instructions from wdt at my previous post but my microSD card with the original factory image is also not booting.
So, in short here's what I've tried to get any kind of video output:
  • Booting manjaro from microSD cards (2 diff models)
  • Booting debian from microSD cards
  • Booting from debian, manjaro, or Ubuntu 18.04 & 20.04 from microSD cards
  • After all that failed I removed the eMMC & tried booting to each of those OSes off the microSD cards.
  • I repeated the same boot tests using the eMMC after reconnecting the eMCC (I flash it via an eMMC to microSD to USB adapter, which connects to my computer), and not using any microSD cards.
  • I disconnected the battery & used only the AC adapter as well, retrying attempts to boot to each eMMC and microSD without success. The system simply sits at a black screen & red power button, or with no indication of power at all.
I also should note I removed my NVMe drive from the system just to make sure there wasn't anything on there causing a problem (it's formatted to exFAT as a simple storage drive).
Any help towards a fix or ideas for troubleshooting would be appreciated.
Because there is a battery, it can get into a non-bootable state and remember it
If you have the back off, the reset button, OR a long press of pwr button
1st, try 8-10 seconds, then regular start press, if that doesn't work, 20+seconds
The "bad" uboot MUST be gone, use something that you are SURE is bootable
And, if nothing is in, nothing will happen. There must be a "good" uboot for any led
There are lots of bad uboots out there, I have had to long press maybe 15 times by now
Do remember, the emmc uboot will be found 1st, if it is bad, must be disabled or removed or blanked
You have saved me from my own ignorance yet again, wdt. I didn't have a very good understanding of uboot before, now I think I have a better grasp on basic troubleshooting. I've got Manjaro 20.10 running on the system again. Thank you, again, for your help.
  Pinebook64 Pro doesn't power on andrea_from_italy 9 8,826 03-20-2025, 10:07 AM
  Lockable-until-power-cycle persistent storage Melab 0 2,682 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 2,962 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 2,623 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 5,327 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 6,881 09-09-2022, 08:13 PM
  Lost my second display WEF 5 9,508 08-18-2022, 07:53 AM
Last Post: josmo
  Replacement Power Cord recommendation? nathanielwheeler 3 6,697 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 4,226 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 11,699 11-30-2020, 10:57 PM
Last Post: rimaille
