Rockbox as an Application on Pinephone
Wink
To create a Rockbox build as an application on the Pinephone using Mobian.
For this I flashed Mobian to a 32GB microSd card which the Pinephone will automatically boot from if inserted.
This is building Rockbox the easy way on the device itself so no cross compiling needed.
On the Pinephone in terminal
 install git:-
sudo apt-get update; sudo apt-get -y install git
download Rockbox source:-
git clone git://git.rockbox.org/rockbox
install:-
sudo apt-get install libsdl1.2-dev
sudo apt-get install gcc
sudo apt-get install zip
sudo apt-get install make
cd rockbox
mkdir build
cd build
../tools/configure
from the table select target 200 for the SDL app
next leave the default screen size to get a pre-installed ready made theme that just fits on the screen, press
enter on the width and height.
then just press enter again to create the makefile.
make
sudo make fullinstall
which will install Rockbox to the device
in terminal type
rockbox
to run the Rockbox application.
I have tested this out and can confirm audio and some plugins work.
Further information here:- https://forums.rockbox.org/index.php/topic,53578.0.html
and https://odysee.com/@Alex_Davis:8/(RaaA)-Rockbox-as-an-application-on-Pinephone:b
Not familiar with Rockbox but if it works well as a replacement media player on an ipod then it should fly on the pinephone.
https://www.rockbox.org/wiki/WhyRockbox
Music
(10-14-2020, 04:48 AM)c3l@ Wrote: To create a Rockbox build as an application on the Pinephone using Mobian.
Yeah, but how does it sound? Rolleyes
I have used Rockbox on a Clip+ for years. This could be a good way to repurpose the Pinephone....
  Mobian image for the PinePhone Korfou 2 1,493 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 65,414 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,719 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,531 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 3,988 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,557 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,362 01-02-2025, 12:47 PM
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 9,660 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 12,455 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  PinePhone won't boot after software update jb2000 2 4,795 03-17-2023, 07:26 AM
