Auto start application on Phosh login
How do you set up an application to run automatically when logging into Phosh? I don't see anything in Settings about auto-starting applications at login and don't see anything obvious under .local or .config.
(09-03-2022, 06:56 PM)Zebulon Walton Wrote: How do you set up an application to run automatically when logging into Phosh? I don't see anything in Settings about auto-starting applications at login and don't see anything obvious under .local or .config.
I assume that Phosh is launched by a specific systemd service, so you could write your own systemd service that launches your desired application, and set the Phosh-launching service as a dependency.
Correct folder to place .desktop file is ~/.config/autostart/
Or install gnome tweaks but it will do excatly the same thing Smile
Good question. I noted that in /config I have a autostart folder with 0 items in it. On Ubuntu 22.04 we can use 'Startup Application Preferences' to add to auto start so I wonder for Mobian users if they can add this application through terminal? I tried on Arch and did not work.
Edit; Probably not much help but in Postmarket Plasma there is an autostart folder and an autostart-scripts folder in .config.
In the autostart folder is a file named .desktop that has a script of sorts in it.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
(09-04-2022, 06:42 PM)Chief Wrote: Good question. I noted that in /config I have a autostart folder with 0 items in it. On Ubuntu 22.04 we can use 'Startup Application Preferences' to add to auto start so I wonder for Mobian users if they can add this application through terminal? I tried on Arch and did not work.
If you want GUI install Gnome Tweaks - there is Startup application setup.
Or you can move any .desktop file to ~/.config/autostart/
Both will do the same - when you boot they will start applications inside ~/.config/autostart/
Right.. I see it and the silly thing is I have Arch Tweaks and Gnome Tweaks installed but I only installed Gnome tweaks for the window min/max buttons. I didn't even notice the startup App aspect - thanks.  Smile
Thanks, I'll give ~/.config/autostart a try. (The "autostart" directory is not there so will create it and see if it works.)
I have the same problem. Does the solution described here work?
(10-14-2023, 06:02 AM)Manieck71 Wrote: I have the same problem. Does the solution described here work?
Yes it does Smile
  New Install, apps start but don't show up on screen?! RT3 2 3,639 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,672 01-15-2025, 08:08 PM
  Screen auto-rotation sensitivity mdk 0 2,546 12-26-2023, 06:08 AM
Last Post: mdk
  Errors when start the system kubussz 2 3,930 11-21-2023, 11:07 AM
Last Post: kubussz
  Using sway along phosh fdlamotte 2 6,442 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 17,384 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 5,456 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 26,521 10-14-2022, 05:38 PM
Last Post: Krafter
Exclamation Impossible to minimize a window with Phosh anonymous 7 10,451 08-18-2022, 01:53 PM
Last Post: dante404
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 5,333 07-16-2022, 02:28 PM
Last Post: dachalife
