[split] U-Boot with NVMe support, keyboard & display working
#51
@NickL - by sleep you mean display sleep or entire system sleep ?
What is your booting success/fail ratio ?
Hi, I would like to try it, but from what I read I am not sure if it is fully working. Does it boot for example ayufan's Ubuntu? Also, where do I get the latest images for SPI flash?
@Wizzard - there are problems with booting kernels > 5.4. For some people only one try on ten boots is successful.
In previous post you have a patch for a newer kernels that circumvents the problems.
There are binary images for eMMC/SD and SPI in my repo.
But I wouldn't try to write to SPI if you don't feel adventurous. Try it on SD first and stay on the safe side.
Good, so are there the binary files with the patch for > 5.4 kernels, or I have to build it?
SD card is a problem for me, cause my SD card slot is broken and does not hold a SD card inside.
You would have to build the kernel yourself.
Some more testing for those of you who want to Smile
@strit from Manjaro has build kernel 5.9-rc7 with the patch that was posted here by @simonsouth.
So grab the kernel from arm-unstable branch, grab uboot from my repo and test. It should be ok.
Please post the results here.
@simonsouth
I have tested your kernel patch. Conclusions :
1. Problem - newer kernels locking/freezing during boot - SOLVED.
2. Problem - screen power management problem (cannot wake screen after it goes off) - SOLVED.
I tried to boot with the patched kernel about 40 times and couldn't get a lock so I would say it's fairly stable patch.
I have also uploaded new version of uboot to my repo.
Added features:
1. Btrfs support.
2. NVME boot option to menu.
If somebody wants to test the binaries ----> https://gitlab.com/as400l/pbp-uboot-display-menu
Remember - to have a consistent booting you must have kernel with @simonsouth patch.
@simonsouth - it is also very plausible that your patch will resolve problem with kexec. Which is there for last couple of years.
But I didn't test it.
I forgot to say - thank you for you work Smile
@simonsouth more good news. You also resolved problem with distortions on the screen after kexec Smile
I have tested today and it works ok. And this problem is present in the kernel for like last 3 years.
Will this patch be accepted into the mainline ?
P.S. I have tested kexec with all the display stuff compiled into the kernel (rockchip-drm, panfrost, analogix-dp etc.). It might make a difference but I don't really think so.
Nice work! It's a pleasure reading and learning from you all...
Sent from my PH-1 using Tapatalk
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,893 04-04-2026, 08:00 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,247 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,827 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 32,861 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,248 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Keyboard issue j0rs 3 5,577 01-20-2025, 07:03 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,802 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,516 12-25-2024, 10:12 PM
Last Post: jessipinkman
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,841 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,099 11-25-2024, 03:42 PM
