Keyboard issue
Keyboard issue
https://forum.armbian.com/topic/47099-ke...are-issue/
Is there any chance to check if the keyboard failure is hardware or software related?
The keyboard stopped working correctly when computer was in the drawer. There was no possibility for any physical damage to the keyboard.
Can I solve the issue by myself or do I need to buy the new keyboard or use my Pinebook pro as a coaster only.
Thanks.
*UPDATE*
On top of keyboard issue - I solved it by buying external usb keyboard.
*I cannot power up my trashy laptop i.e. PBP.*
1a. battery disconnected, I used bypass cables.
eMMC with Armbian
U-Boot TPL 2020.10-armbian (Aug 08 2021 - 16:26:56) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200) Trying to boot from MMC2 NOTICE:  BL31: v2.5(release):c158878-dirty        NOTICE:  BL31: Built : 16:26:51, Aug  8 2021        U-Boot 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200)        SoC: Rockchip rk3399        Reset cause: POR        Model: Pine64 Pinebook Pro        DRAM:  3.9 GiB        PMIC:  RK808        MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0        Loading Environment from SPIFlash... Invalid bus 0 (err=-19)        *** Warning - spi_flash_probe_bus_cs() failed, using default environment        In:    serial        Out:  serial        Err:  serial        Model: Pine64 Pinebook Pro        Net:  No ethernet found.        starting USB...        Bus usb@fe380000: failed to get usb phy        Port not available.        Bus usb@fe3a0000: failed to get usb phy        Port not available.        Bus usb@fe3c0000: failed to get usb phy        Port not available.        Bus usb@fe3e0000: failed to get usb phy        Port not available.        Bus dwc3:
All led are dead.
1b. - eMMC is disabled, Armbian on sd card
U-Boot TPL 2020.10-armbian (Aug 08 2021 - 16:26:56) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200) Trying to boot from MMC1 NOTICE:  BL31: v2.5(release):c158878-dirty        NOTICE:  BL31: Built : 16:26:51, Aug  8 2021        U-Boot 2020.10-armbian (Aug 08 2021 - 16:26:56 +0200)        SoC: Rockchip rk3399        Reset cause: POR        Model: Pine64 Pinebook Pro        DRAM:  3.9 GiB        PMIC:  RK808        MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0        Loading Environment from SPIFlash... Invalid bus 0 (err=-19)        *** Warning - spi_flash_probe_bus_cs() failed, using default environment        In:    serial        Out:  serial        Err:  serial        Model: Pine64 Pinebook Pro
2. Battery is connected (with reset), eMMC disabled.
All led are dead.
Do you think that it’s a sign of a software issue rather than hardware?
[/url]
[url=https://forum.armbian.com/topic/47099-keyboard-is-it-software-issue/]https://forum.armbian.com/topic/47099-keyboard-
Geometry Dash Lite-is-it-software-issue/
I'm confused because PBP was stored in a drawer after update&&upgrade.
What could happen to the keyboard in the drawer? I have no idea. That's why I thought  that maybe this is somehow firmware related?
I have had a lot hardware and software related issues with PBP. To be honest with this device everything is possible.
The thing is, how can I exclude software or hardware defect without investing money in the new keyboard? I don't want to invest >$1 in this product anymore.
Put a different OS on a micro-SD card. Boot that and see what happens.
On these devices there is certainly the possibility of hardware damage if stored in a drawer. The battery can puff up and cause mechanical damage. I've had it happen. I haven't had damage to the keyboard but I can see how it could happen. I don't suspect this is your issue though.
In any case if you get to a point where you give up on it please don't "recycle" it. There are many of us here who would jump at the opportunity to try to fix it.
:wq
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,848 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,101 11-25-2024, 03:42 PM
  Dead Pinebook Pro Keyboard Keys calinb 2 4,469 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 3,015 07-20-2023, 11:06 PM
Last Post: papable
  Newbie with immediate issue jasonumd 1 3,800 03-04-2023, 05:59 PM
Last Post: hacknix
  ISO keyboard Pinebook pro for sale tgrauss 3 7,450 11-01-2022, 04:45 AM
Last Post: tgrauss
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 6,779 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,668 09-14-2022, 03:56 AM
Last Post: Carl
  suckless surf on arch linux pinebook pro scrolling issue gehn5 0 2,933 04-16-2022, 07:41 PM
Last Post: gehn5
  Selling PineBook PRO with ISO Keyboard + NVME firefox-58 27 40,949 04-08-2022, 06:23 AM
Last Post: firefox-58
