Remote for Android?
Shocked
Hi everyone!
I just ordered my Pine64 and I wanted to use it with android on my TV.
However I was wondering if there is a way to control the android with something else than a mouse and keyboard. I was a raspberry pi user (with OSMC on it) and I controlled it with my phone.
The goal for me is having on the Pine apps like netflix, kodi for having my complete media center, and some games like angry birds that I can play with a remote.
Is something like that possible?
Thanks a lot!
(04-30-2016, 04:00 AM)liodra Wrote: Hi everyone!
Thanks a lot!
Just get the Pine64 IR remote control kit. You also can configure your Harmony remote or others universal remote using the IR code, http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg, provided at Pine64 wiki page. Please remember to add an IR receiver (3 pins) in front of the Pine A64 board.
You don't need IR remote control kit, you just need the BT module.
Then, you will be able to use any bluetooth controller.
BUT, @tllim , I can't enable the BT on your last android release :/ Can you?
Thank you for your responses!
I have ordered with the bluetooth (and wifi) module so I'll look for bluetooth controller!
But how will it work? Since on android this is a mouse?
(04-30-2016, 03:21 PM)liodra Wrote: Thank you for your responses!
In general, the Bluetooth remote controller that designs for Android should work.
I just ended up getting a bluetooth keyboard with a built-in track-pad.  Got the Logitech K400 for $25 on amazon prime. It has been working great for me, and cuts out the need for line of sight as needed by IR remotes.
Thanks a lot!
What IR module? Spec, part # etc?
Thanks a lot!
Here is IR Remote Control info: http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg
What about HDMI CEC? We could use the TV remote control...
Yes...CEC would be the best option. I am not sure why there is no Update on when CEC will be implemented.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,564 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 606,781 12-29-2020, 01:13 AM
Last Post: firmwarefile
  Adding an accelerometer to Android modsbyus 11 31,999 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,670 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,232 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,549 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,732 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 409,105 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,492 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 162,379 02-10-2019, 07:44 PM
Last Post: mmmarcus
