Pinephone
Hallo all,
Sorry to bump in like this, I am struggling to connect my phone to my pc, it is not picking it up, what must I do
My camera is also not working
And it does not pick up my sd card
Any url that might assist with the issues please
regards
We don't know which OS you are using.
I would suggest trying out mobian.
https://wiki.mobian-project.org/doku.php?id=install
Back camera works.
Connection to a PC using an USB cable is more trickier, though.
If you haven't modified your phone, it won't work. See:
https://forum.pine64.org/showthread.php?tid=10255
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Hello,
Back camera works.
Thanks for the reply
I am using UBports
I dont mind if the front camera is not working as yet
I will test my Carrier connection today to see if it is working, if not I will swicth to Mobian then
regards
https://forum.pine64.org/showthread.php?tid=9796
Also check this link. The update channel you are using could make a difference.
(07-22-2020, 03:31 AM)fernando_c_m Wrote: Connection to a PC using an USB cable is more trickier, though.
That's not entirely true. Connection to a Type A port with the supplied cable (or a similar one like the one supplied with the Pixel) will work - it's how you'd typically use jumpdrive to flash to the eMMC. It's host mode, and maybe connection to other USB C ports, that won't work.
You're right. Jumpdrive certainly works.
As it was implied, that it didn't work, I thought it was meant connecting the PP running one distro to a computer using the supplied USB cable, which in my case does not work given I haven't made any hardware modification.
lsbus does not report any new device having been attached when I connect the PP to my laptop running debian. You can imagine what will happen on other non linux based OS. : )
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 161 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 2,967 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 418 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 370 11-18-2025, 03:07 PM
  Pinephone visibly losing power while plugged in Hiraghm 7 4,611 10-21-2025, 10:38 PM
Last Post: Anthona
  Pinephone boot. Richy_T 8 4,445 10-21-2025, 12:12 PM
Last Post: Richy_T
  How can I record video on a Pinephone? kk22 22 15,021 10-08-2025, 01:29 PM
  Does PinePhone support long-term battery health optimization? roseblack 5 1,315 10-06-2025, 09:05 PM
  iso pinephone for sale (USA) elwoodb25 0 3,840 09-24-2025, 09:25 PM
Last Post: elwoodb25
  Why projects like PinePhone matter – feedback and encouragement Gary2003 13 18,239 09-16-2025, 01:13 PM
Last Post: Gary2003
