[Possible solution] Stuck on blank screen
It seems that being stuck on a blank screen after the pine64 splash screen is a pretty common issue lately. Most of the time it happens after an OTA update but for me, it happened as well when I hard shutdown my PinePhone after being unresponsive.
I'm not sure if this is always the case but here's some steps you can try to recover your UT installation.
  1. Shutdown your PinePhone.
  2. Press and hold Power + Volume Up until it boots to the recovery mode screen (one that shows Installing Update)
  3. Connect your PinePhone to a desktop/laptop via USB cable.
  4. Check if all partitions in your UT installation, either emmc or sd card, can be mounted. In my case, the userdata is corrupted and cannot be mounted.
  5. If you found a partition that cannot be mounted, run the command below
    sudo fsck /dev/<partition id>exampleConfusedudo fsck /dev/sdb10
  6. The command will check for errors and you will be asked if you want to fix them. Just answer Y in those questions.
  7. Eject your PinePhone and shut it down.
  8. Turn it on and see if it boots properly now.
Thx! This worked for me. Userdata was corrupted.
Thank you, this worked for me as well.
can this also happen when flashing newly to the SD card?
i just flashed the sd with ubports and after one successful boot, its blank/black.
Maybe caused by this https://forum.pine64.org/showthread.php?tid=9832
  Screen-off = dead phone okgo 11 22,343 09-27-2021, 07:53 PM
Last Post: jtn0514
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,206 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
Sad Help! - Screen blank after update. Zweitaktmotor 4 10,897 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  noticable Screen flicker KNERD 0 3,631 01-13-2021, 09:00 PM
Last Post: KNERD
Star Updates stuck on stable channel. Cree 6 13,394 10-04-2020, 11:26 AM
Last Post: Giiba
  Copy To SD Card, All I get Is Red Light & Black Screen . . . . NobodyNew1 9 19,999 09-13-2020, 08:59 PM
Last Post: NobodyNew1
  Black screen after pine64 logo Putergenius 2 6,012 07-21-2020, 05:15 PM
Last Post: natasha
  #48 Screen Resolution Zweitaktmotor 3 8,182 06-15-2020, 02:51 PM
Last Post: colin hodsdon
