07-19-2020, 05:15 PM
Hi I just recieved mine it worked at first but was slow and glitchy and it froze since then it just says Pine64 logo then black screen.
Any help is appreciated
Black screen after pine64 logo
07-20-2020, 02:57 AM
I'd guess you're running low on battery. I needed a 3A USB-Loader to get mine charging.
07-21-2020, 05:15 PM
turn it off, remove the sticker that protects the battery, give a nice charge using charger (not in the computer, it won't charge) and try again.
If fails try to reinstall UT check https://forum.pine64.org/showthread.php?tid=10130 |
| Ubuntu Touch on Pine64 | Rondarius | 11 | 17,341 |
10-11-2023, 12:36 PM Last Post: Rondarius |
| Screen-off = dead phone | okgo | 11 | 22,237 |
09-27-2021, 07:53 PM Last Post: jtn0514 |
| PinePhone UBPorts Edition stuck on PINE64 logo screen | Giovanni Iannotti | 4 | 12,163 |
09-01-2021, 01:20 PM Last Post: Giovanni Iannotti |
| Images won't boot past pinephone logo | remington_luger | 9 | 20,710 |
08-22-2021, 09:56 AM Last Post: remington_luger |
Help! - Screen blank after update. | Zweitaktmotor | 4 | 10,861 |
07-26-2021, 05:17 PM Last Post: Zweitaktmotor |
| noticable Screen flicker | KNERD | 0 | 3,626 |
01-13-2021, 09:00 PM Last Post: KNERD |
| Copy To SD Card, All I get Is Red Light & Black Screen . . . . | NobodyNew1 | 9 | 19,977 |
09-13-2020, 08:59 PM Last Post: NobodyNew1 |
| [Possible solution] Stuck on blank screen | kugiigi | 4 | 9,950 |
06-29-2020, 02:51 PM Last Post: rocket2nfinity |
| #48 Screen Resolution | Zweitaktmotor | 3 | 8,171 |
06-15-2020, 02:51 PM Last Post: colin hodsdon |
