Can't boot up Manjaro 20.04 eMMc image from SD card...
#21
(06-23-2020, 12:37 PM)nathanielwheeler Wrote:
(06-23-2020, 12:35 PM)rick1959 Wrote:
(06-23-2020, 12:31 PM)nathanielwheeler Wrote:
(06-23-2020, 08:08 AM)carlosqueso Wrote:
(06-23-2020, 06:35 AM)rick1959 Wrote: I've been able to install either Manjaro XFCE or KDE....However, when it comes to running the first update, I get an error message saying that "usr/lib/P11-kit.trust" already exists and then terminates the update.
Being that it occurs regardless of which image, KDE or XCFE, I use (both were checksummed) I get the same issue.
So, it seems there's something going on. Wonder if my PBP has an internal problem....
So I think this is an issue with Arch.  I had to run:
pamac update --overwrite /usr/lib\*/p11-kit-trust.so
to get the updates to install.
Got the idea from here: https://www.archlinux.org/news/nss3511-1...ervention/
but changed it to use pamac instead of the upstream Arch.
How do I access wifi from the microSD?  iwconfig and netctl aren't installed, so I'm not sure how I can update this library.
You're using the NON-eMMC file (image), right? On the SD card...?
Yes, currently logged in as root@manjaro-arm, which is the microSD card.  I suppose I could log into the eMMC as debian, but I don't know how I would make changes from there to the microSD image.
In my experience, using non-eMMC images, the image boots right up and you select the network icon...With the eMMC image you have to wait until it boots after the install...Does this help? :-)
#22
(06-23-2020, 08:08 AM)carlosqueso Wrote: So I think this is an issue with Arch.  I had to run:
I can't access any kind of GUI on the image.  The image on the microSD itself is the ARM Manjaro eMMC installer, which crashes as soon as I try and have it target the eMMC.  When it crashes, it exits to a text-only shell running bash and logged in as root@manjaro-arm.
#23
(06-23-2020, 12:31 PM)nathanielwheeler Wrote: How do I access wifi from the microSD?  iwconfig and netctl aren't installed, so I'm not sure how I can update this library.
Interesting....
Using eMMC installer image, it's all scripted command line info. BUT FIRST, you have to hit any key to get things rolling AFTER the Manjaro symbol and spinning wheel have been there for 15 or 20 seconds. Then it runs you through a few questions to be sure you know what your doing. Then, after it expands the compressed image, if asks you want to install. Once done, it tells you it'll shut down so you can remove the SD card... Boot up and you have ....Somewhere along the line it'll ask about user ID's, passwords and time zones and such...Anyway, NO GUI for eMMC install..But it should be pretty straightforward...
P.S. Did you checksum your image?
#24
(06-23-2020, 12:35 PM)rick1959 Wrote: You're using the NON-eMMC file (image), right? On the SD card...?
Interesting....
Yes, using sha256sum.
#25
(06-23-2020, 12:37 PM)nathanielwheeler Wrote: Yes, currently logged in as root@manjaro-arm, which is the microSD card.  I suppose I could log into the eMMC as debian, but I don't know how I would make changes from there to the microSD image.
Interesting....
I'm stumped. Perhaps someone else has an idea.
I've been told some SD cards don't work well, for what reason I can't understand.
Have you tried other images for different OS'es to see if there's a difference...?
Sorry to not be of more help...
#26
I have made a new thread detailing a guide I wrote based on a successful replacement of the default OS: https://forum.pine64.org/showthread.php?tid=10403
It isn't relevant to this thread in particular since it is based on Manjaro 20.06.  I hope it helps newbs like me replace their systems with fewer tears.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,725 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  What's a good image to use now? [tutorial help as well] frank_philip 40 20,004 07-18-2025, 07:28 PM
  Boot Order in Pinebook Pro food 11 11,391 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,107 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 10,849 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,636 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,919 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 3,180 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 12,314 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,493 02-02-2024, 02:45 AM
Last Post: frankkinney
