Pinebook Pro structural integerity failing
#31
Well, the Pine64 people are learning. As has been said, the newer ones, (though it's unclear if it's ANSI only, or both ANSI & ISO), have a better plastic.
I've added a comment in the Wiki Troubleshooting on this issue. It's not very helpful, in the sense their is little to do, except replace. But, replacements are now available. And if someone wants to expand the Wiki section on this issue to include work arounds, repairs or outright re-enforcement, feel free.
Here is the section:
Wiki - Pinebook Pro - Cracks in the plastic
As usual, feel free to correct, improve or comment, (good or politely bad).
From what people have said, it made be possible to improve the structural integrity of the chassis using something like epoxy resin. I've ordered an ANSI keyboard replacement for my ISO model. Whence that arrives I may perform re-enforcement before I install it.
Arwen Evenstar
Princess of Rivendale
#32
(05-25-2020, 11:42 AM)Arwen Wrote: Well, the Pine64 people are learning. As has been said, the newer ones, (though it's unclear if it's ANSI only, or both ANSI & ISO), have a better plastic.
That's useful to know! Please post a guide to any reinforcement you do and link to it here-any advice helps.
#33
(05-25-2020, 04:52 AM).TDC_PBP Wrote:
(05-25-2020, 03:07 AM)vfr400racer Wrote:
(05-25-2020, 12:27 AM)hdk Wrote: My PBP broke again; the hinges came completely off. The palmrest is of extremely inferior quality.
The little plastic that holds the connection from screen to motherboard broke in 4 little peaces.
Support @ pine can or will not help in any way.
Disappointed adieu.
I bought a new one from the pine store. The recent ones are made of another plastic than the original ones. And they are only ~20USD.
Yes, but with shipping to the US they cost more like $32   Sad . While I am waiting for my replacement part, I have tried to glue my Pinebook Pro's crack near the hinge multiple times (the crack is on the upper left hand side of the keyboard) with regular Loctite, but it seems that it isn't strong enough, as it has cracked multiple times. I have bought Loctite's Plastics Bonding System from Amazon, and when I get it I plan on applying the glue on both the top and bottom of the crack and hoping for the best. This whole plastics thing is ridiculous!
I would suggest to modify the hinges, too. At least that is what I did. They are so hard to operate and put much stress on the tiny nuts and their fragile seatings.
#34
Disappointed adieu.
Amen to that! Make sure to post back in the forum if your modification works!
#35
My new palmrest came in today. I think it's better then the original.
I was ready for it: fixed the hinges, can now lift the screen with my pink.
The only hard part was the trackpad, had to use some force.
PBP out of the coma alive and kicking.
I'm in love again.
Will tell you my experiences in two weeks
#36
(06-15-2020, 01:56 PM)hdk Wrote: My new palmrest came in today. I think it's better then the original.
I'm in love again.
What modifications did you make to your PBP's hinges?
#37
I'm in love again.
Be patient, take your time
take the hinges off the screen, wrenching
make the hinges slowly wider, with a screwdriver 0,8 mm you can get in between the joint
#38
I'm in love again.
Ok, so I need to remove the hinges and then widen the hinges with a .8 mm screwdriver shaft-is that right?
#39
I'm in love again.
that's right
#40
I'm in love again.
that's right
Ok, thanks!
  Updated Pinebook Pro? tantamount 2 2,330 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,106 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,786 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,398 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,821 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,710 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,967 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,838 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,220 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 29,948 03-09-2025, 11:17 AM
Last Post: davisthomas
