Sway on PinePhone POC
I got inspired by the cool sxmo project and decided to try something similar with my favorite tiling compositor: Sway. I've put together a proof of concept (POC) solution which consists of several config files and shell scripts. You can find it here: https://github.com/Dejvino/pinephone-sway-poc
There are various menus and shortcuts to help you avoid using the on-screen keyboard all the time. E.g. touching the backlight indicator spawns a custom dialog where you can change the settings. You can also use touch gestures to do some common tasks like move terminals around etc. Pressing the power button puts the phone into "sleep" mode to avoid draining the battery that much (replacing  the default shutdown action).
Be aware that this is just a bunch of configs that you can apply to your existing postmarketOS installation. Not a full image. Plus it likely has some gaps. But I think it could be helpful for someone anyway. It's surprising how much you can achieve with just the sway config file!
But that's not all! Even if you don't care about sway you might want to check out pinephone-toolkit which is a collection of UI-agnostic tools for controlling the LED, backlight, vibrations and putting the secondary CPUs into sleep. These should work with any distribution, so it is a nice building block.
Could it be made to work with a debian based distribution?
(06-02-2020, 11:06 AM)nas Wrote: Could it be made to work with a debian based distribution?
I expect it could. Likely all you have to do is replace "sudo apk add X Y Z" with "sudo apt install X Y Z" and it will work Smile  There is nothing really postmarketOS-specific there, maybe apart from using "elogind-inhibit" instead of "systemd-inhibit", but that should be it.
This is pretty neat and cool to see lisgd pop up somewhere else too Wink
I'll have to play around with this, I'm particularly interested in the program you have in pinephone-toolkit `cpu-sleep` to put certain CPUs offline. (Curious how that'd work out for say continuing to listen to music or something, e.g. does that still work; and is there a big battery life gain - do you have any stats for batterylife in this single-cpu/low-cpu mode?)
Also curious how manageable sway is with gestures - one problem I had with lisgd and gestures is that if your finger generally overruns multiple windows, you wind up switching window focus (atleast in dwm, and that throws off the meaning of the gesture); but curious how this worked out in your setup and how reliable it is. Will have to play around with this when I get some free time or if you wind up making an ISO that would be awesome.
(06-02-2020, 06:23 PM)mil Wrote: This is pretty neat and cool to see lisgd pop up somewhere else too Wink
To be fair putting CPUs into sleep doesn't do anything fancy, just `echo 0 > /sys/devices/system/cpu/cpu1/online` for 3 out of 4 CPUs Smile  I don't have any statistics, but looking at the charging current it helped only slightly. I ran just one test: leaving it idling in the "sleep" mode, after 6.5 hours it had 7 % battery left, proving I could use it off the grid Big Grin
When going to sleep while playing music, there is a brief but audible skip if the player's process gets transferred to the primary CPU. Otherwise it works great and one CPU manages to play a song no problem.
Focus in sway is controlled more explicitly, so it stays where you set it. On the other hand the source touch events get propagated to the underlying windows. You may get some unwanted actions this way Smile
I wanted to avoid diving into the problems of how to build an image with everything included, but if this PoC turns out usable, I'll reconsider it.
as an avid sway user on pinebookpro i just wanted to say thanks for this, and if a pinephone happens in my life i'll be back. Wink
  asterisk or FreePBX on pinephone? vanja 0 790 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 24,969 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 7,850 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 244,362 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 230,732 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,306 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,592 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 70,698 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,049 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 79,557 07-26-2024, 10:35 PM
