Pinebook Pro stuck in suspend
My PBP seems to be stuck in suspend mode. The power indicator LED is constantly red when the system is powered on, and the screen does not turn on. The power LED is normal (red) when plugged in, and the battery seems to be holding a charge. I've tried the reset button on the main board. I'm not sure what else to try. Any suggestions? Thanks in advance!
Press and HOLD power button ~20 seconds (+) for a complete power off ???
^before doing that connect power
(05-02-2020, 06:39 PM)xmixahlx Wrote: ^before doing that connect power
Hi, sorry for the delay in replying. I tried as you suggested holding the power button down for 20+ seconds several times with and without the power attached. The display is still not powering on. Any other suggestions? Thanks
Remove emmc, mrfixit's on SD (because of uboot, just a hunch)
Serial cable
  Replacement battery for PineBook Pro DrYak 5 8,492 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 9,507 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 4,659 03-23-2025, 03:31 PM
Last Post: WEF
  best way to get a stuck sd card out? elix 3 4,791 03-14-2025, 02:43 AM
  Yet another new Pinebook keyboard problem MikoBob 3 5,275 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,550 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 4,579 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,658 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 229,582 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 14,749 01-18-2023, 07:41 PM
Last Post: ottahe
