best way to get a stuck sd card out?
so i have always had problems with the micro sd card in my pinebook pro.
the micro sd card is now stuck and i wanna switch distros.
i tried the old knife method, etc. but ended up screwing up the outer part of the card.
is my next bet to the case off and get it out that way?
not sure its even safe to use the card at this point.
thanks
Taking the case apart only gets you marginally better access if my memory serves.
Your best bet is probably a good tweezer or small needle noise pliers.
:wq
(03-13-2025, 07:04 PM)KC9UDX Wrote: Taking the case apart only gets you marginally better access if my memory serves.
But be VERY careful.
Trying to lever a SD card out will easily destroy an SD card, I did it to a 500gb five years ago when it was $$$.
Last try glue something like parachute cord outer to the card and chip the epoxy off later.
(03-13-2025, 02:41 PM)elix Wrote: so i have always had problems with the micro sd card in my pinebook pro.
By the way, you may want to abandon the card and get one of these to solve that problem.
https://pine64.com/product/pinebook-pro-sideboard/
:wq
  Write to an A1-rated Micro SD card failed dsimic 12 22,426 07-28-2021, 11:38 AM
Last Post: dsimic
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 8,865 04-02-2021, 06:45 PM
Last Post: tkudog
  microSD card stuck charlesnorris 7 15,866 11-19-2020, 05:11 AM
  NVME SPI Update not booting SD Card WZ9V 5 11,823 10-18-2020, 08:36 PM
  Upgrade eMMC card - boot problems alpopa 0 4,190 09-16-2020, 12:31 PM
Last Post: alpopa
  PBP not booting screen blank after SD card boot Jakobp 10 23,768 08-18-2020, 08:56 PM
Last Post: trinapicot
  Privacy switches - cutting power to wifi card as400 1 5,263 08-10-2020, 09:48 AM
Last Post: belfastraven
  Pinebook Pro stuck in suspend charlief0x 4 9,443 05-05-2020, 08:36 PM
  SD card slot stefan.schumacher 1 5,228 03-28-2020, 04:34 PM
Last Post: zaius
  USB-C HUB: sd card slots and USB ports not usable vfr400racer 2 7,326 12-15-2019, 03:50 AM
Last Post: vfr400racer
