Retropie on Pinephone
I borked my system and now the pinephone only boots to a blank screen. So I'll take this opportunity to reinstall retropie and record my steps as I go.
Edit: Moved the installation instructions into post #3
Notes: Emulationstation will launch games on a fresh install but fiddling with retroarch config settings seems to break it. The xmb menu driver for retroarch frontend was previously fast but unresponsive after reinstall. I was unable to get to the bottom of it so change the menu driver to rgui to avoid the headache. Select the terminal keyboard on squeekboard and the default keys for navigating the menu are capital W and X for left/right, F4 for enter, capital Z for down and the up arrow key for Up. Capital P and O are select/back keys. Disable audio-sync and video vsync settings for best emulation performance. Enable sync to content frame-rate to deal with overspeed. Select tinyalsa for audio driver to minimise stutter.
Extra: The xmb menu lag was caused by installing assets, ie the menu icons. Looks like you can disable shadows, smoothing, etc but simplest option is to uninstall the assets. Go to the configuration tool in the retropie script menu and uninstall them from there.
does retroarch has a mobile UI with on screen controls??? i Know in android it has but i dont know if that is a separated android implementation only....
(05-06-2020, 05:50 AM)paju1986 Wrote: does retroarch has a mobile UI with on screen controls?
I'm not a fan of touchscreen controls but should be possible according to this link - I haven't got retroarch installed currently so unable to test.
Edit: The joypad overlay shows up but probably need to remap the keys to make it work.
.jpg   retroarch-virtualpad.jpg (Size: 62.36 KB / Downloads: 744)
  asterisk or FreePBX on pinephone? vanja 0 778 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 24,911 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 7,811 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 244,136 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 230,452 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,287 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,575 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 70,563 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,028 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 79,436 07-26-2024, 10:35 PM
