Fedora + Phosh for PinePhone
(03-21-2020, 10:02 PM)bcnaz Wrote:
(03-21-2020, 08:30 PM)njha Wrote:
(03-21-2020, 08:14 PM)bcnaz Wrote: I see software package downloads, but I do not see any complete OS downloads on the pages linked in your posts.  ?
Look under assets at the bottom of each release? Release 4 is the latest one, it's the file ending in .zst. Just flash that as per the instructions.
OK so I have it downloaded,
  When I attempt to use Balena Etcher to flash it to an SD card,  Balena Etcher warns me this is NOT a bootable image ?
You have to extract it first. https://stackoverflow.com/questions/4535...ng-tar-zst
$ tar -I zstd -xvf archive.tar.zst
*.*.* PinePhone BraveHeart edition w/ distro: Debian + Phosh // GuixOS, Debian, Arch // pocket linux enthusiast // washed up sysadmin *.*.*
I tried a few times "NO JOY"
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(03-23-2020, 01:08 AM)bcnaz Wrote: I tried a few times  "NO JOY"
in terminal i just copy and pasted, the command , dragged and dropped ,the file location, and it extracted to the same location.
wallah !!!
I attempted to install software app that can compress/uncompress  the zst file,  but somewhere along the line it did not take.
There are other OSes that I can work with and try.
I will watch for this,  if they add files   " I can 'use'  I will try it again then".
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I had also a bit of problems with uncompress of this image. The developer should use another file compression instead of zst.
I also had issues decompressing and flashing the image to sdcard, but I managed to get it working:
1. Install and use zstd to decompress image:
zstd -d fedora-rawhide-aarch64-mobile-04.img.zst
2. Use balenaEtcher to flash image to sdcard
I tried using dd to flash the image multiple times, but the sd card wouldn't boot. I flashed using balenaEtcher, and it booted just fine. I'm not sure why, though. I usually use dd, and don't typically bother with graphical image burning software.
My first attempt to flash Fedora also failed. I then flashed it with the Fedora Media Writer tool, that worked very well.
Just a quick update- as you may have noticed, progress has been stalled for a few weeks.
That's because we're moving from...
- the custom COPR repository
- manually starting the kernel
- Megi's 5.6 kernel
To...
- the upstream Fedora 33 repository
- EFI boot (with GRUB! just like your desktop!)
- upstream 5.7 kernel with selected (still necessary) patches
Currently, almost all the packages we need are in Fedora 33, and I have a working kernel build. Once EFI is figured out, I should have another image uploaded.
(04-15-2020, 04:37 PM)njha Wrote: Just a quick update- as you may have noticed, progress has been stalled for a few weeks.
- Megi's 5.6 kernel
To...
I look  forward to your next release,
but
I hope that will be an easier to work/flash download file ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Thanks for the work. Awesome, I use Fedora for all my systems and look forward to use it on the phone. I might start assisting in the future if my spare-time allows
  asterisk or FreePBX on pinephone? vanja 0 875 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,409 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,079 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 246,875 04-03-2026, 08:37 AM
Last Post: baptx
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,381 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,692 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 71,762 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,143 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 81,139 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 8,146 07-04-2024, 07:34 AM
