How to boot Manjaro from NVME with uboot on eMMC
#41
I installed Manjaro to my eMMC. I followed the tutorial until it said to edit the file boot.txt in /boot. There is no boot.txt. I looked in the chroot /boot as well as the eMMC /boot. Both have the following files/dirs:
ls -a
. .. dtbs extlinux idbloader.img Image Image.gz initramfs-linux.img u-boot.itb
Am I doing something wrong?
p.s. - I love the look of Manjaro - sweet looking with KDE Plasma.
#42
Never mind. I install the spi-flash image, used the Micro_SD to install directly to the NVME, and then disabled the eMMC with the switch. It works like a charm. Woo hoo!
#43
(03-26-2020, 03:20 PM)fretinator Wrote: Never mind. I install the spi-flash image, used the Micro_SD to install directly to the NVME, and then disabled the eMMC with the switch. It works like a charm. Woo hoo!
Great to hear. You were doing everything right but Manjaro is not using boot.scr anymore. They are using extlinux.conf now.
I think I will have to update my howto - thanks Smile
#44
As Manjaro now uses extlinux.conf it is also possible to keep the config file unchanged and just name the system partition on NVME as “ROOT” and the others something different. Works well on my pbp
#45
got my new PBP yesterday. Ordered it with the NVMe adapter and an 512GB Intel NVMe. All good so far. Manjaro off the emmc card is running fine.
Now I wanted trasnfer my Manjaro installation from emmc to NVMe. But the newest release of Manjaro now uses a /boot formatted with FAT16 and a / as root partition.
How about to handle this? I think the explanation/guide from first post has to be modified?
TIA
Uwe
#46
@firefox-58 create two partitions. One for /boot (it has to be first on the disk) and the other for rootfs. Copy everything from /boot on eMMC to boot partition on nvme drive and rsync the rootfs.
I'm not sure how /etc/fstab looks on new Manjaro. Paste it here so I can take a look.
#47
Here it is:
# Static information about the filesystems.
# See fstab(5) for details.
# <file system> <dir> <type> <options> <dump> <pass>
LABEL=BOOT_MNJRO /boot vfat defaults 0 0
#48
If you label your partitions the same names as Manjaro guys do then you don't have o change fstab.
  Install Tow-Boot on the SPI Shad0w 14 47,707 11-18-2024, 11:23 AM
Last Post: reukiodo
Question Can't Boot from MicroSD (What Am I Missing) falken 10 16,602 04-28-2023, 04:26 PM
Last Post: pinemouth
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,949 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 25,029 07-31-2021, 04:44 AM
Last Post: jiyong
  How to rewrite uboot to emmc pineitup 5 15,812 12-27-2020, 10:35 AM
Last Post: nightranger73
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 164,841 12-22-2020, 03:05 PM
Last Post: Wizzard
  Make your own Manjaro image flatulent_piney 0 6,643 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 13,128 10-24-2020, 06:38 AM
Last Post: pineitup
  Tutorial: Run Debian off NVMe hive 4 12,425 10-19-2020, 10:09 AM
Last Post: hive
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,620 10-02-2020, 12:20 PM
Last Post: wrzomar
