03-18-2020, 12:02 PM
03-18-2020, 03:10 PM
(03-18-2020, 10:31 AM)buskmann Wrote: Thanks for the response. tbh it's easier to use Jumpdrive after you build the image on a computer
*.*.* PinePhone BraveHeart edition w/ distro: Debian + Phosh // GuixOS, Debian, Arch // pocket linux enthusiast // washed up sysadmin *.*.*
03-18-2020, 05:29 PM
Should we just do 'Updates' for now or wait for new releases to download ? Thanks !
LINUX = CHOICES
**BCnAZ** Donate to $upport your favorite OS Team
03-18-2020, 08:43 PM
If you want to drain that battery a bit faster, you can run some games via retroarch - here's a low res video demo.
03-19-2020, 03:07 AM
03-19-2020, 03:14 AM
I was able to build at 6.
Not at 10am. A gnome Bluetooth dependency it seems. I'll retry later
03-19-2020, 03:40 AM
(This post was last modified: 03-19-2020, 03:49 AM by bcnaz.
Edit Reason: NOTE :
(03-19-2020, 03:07 AM)a-wai Wrote:(03-18-2020, 05:29 PM)bcnaz Wrote: Should we just do 'Updates' for now or wait for new releases to download ?Just go with apt (or gnome-software) for updates, I'll probably be switching to a weekly release cycle. **** 'Gnome Software' showed updates available a few times today, so I ran them. Now my contact book seems to be working better ? I was having trouble connecting the incoming numbers with the names in the contact book, now they all have names. At low screen brightness I get quite a bit of screen flicker ? (but perhaps that was because the battery was at about 12%) With only the phone on, and wifi, bluetooth, data, and screen off, the phone was a little warm. NOTE : After using Balena Etcher to flash this SD card I ran 'Disk' and resized to the full 31.9gb of the SD card. any comments on that ?
LINUX = CHOICES
03-19-2020, 05:25 AM
03-19-2020, 05:40 AM
thanks to Dukla who advised me to try this distribution (debian-pinephone-20200314 version) I want to report my experience.
Working: - the calls work both outgoing and incoming, the audioo is not perfect (but I had launched an AT command with pmos and probably have to launch another one to compress the audio less) - I can switch between the two speakers during the call - sms work, the only problem is that I don't have the notifications for the sms arrived and I have to check periodically - wifi working - gps working! - i'm not sure yet, but it looks like i don't have the battery draining problem while the phone is off Trouble: - mobile data not working, if I activate the switch the call signal goes away too (do I have to give some command at to activate the modem?) - sometimes there are problems with the touch that seems to lose calibration until a reboot - I noticed that by pulling down the panel (which also contains the power off button) and pressing the side button to turn off the screen (without pulling up the previous panel), when I turn on the screen again the touch doesn't respond anymore and the only thing I can do is to turn off the phone by holding down the side button for a long time (is this a dangerous operation? someone told me that I risk to damage the modem firmware by not following a proper shutdown procedure) - the keyboard does not have the keys I use with the pc, such as alt, ctrl, function keys, unfortunately these are indispensable with linux. Example I can't save files edited with nano. - resolution: what is the resolution of the phone? I have some applications that start at a fixed resolution but it seems to me that they still come out of the screen. And for these programs, I don't know how to resize and/or move the windows and so even if the programs work, I can't use them! - cam not working, but it is already knowed Anyway, the impression you get from the phone is that I finally have a free and open device in my hands, so thanks again for your efforts. |
