Broken power key or keyboard, can I still turn it on?
Since I spilled water on my keyboard, I have with the help of a 2nd pinebook narrowed down the issue of its nonfunction to the power button itself. I simply can't find an alternative way to turn it on. How do?
What happened to the active community for this thing?
It's still cool, where are you?
I'll reverse engineer the keyboard my own self.
(03-15-2020, 12:58 PM)aaspectre Wrote: What happened to the active community for this thing?
You shouldn't have to reverse engineer anything. There are schemattics (although it is also useful to take a look at the device tree to see how the power key is specially handled):
https://wiki.pine64.org/index.php/Pinebo...ifications
Based on the schematic and devicetree, I'm pretty certain the power key is a simple physical button and it bypasses the keyboard controller entirely. There's a signal running directly from the 30 pin connector to the PMIC PWRON pin, I think this is the power key.
Yeah, it appears stuck in the on position. So I just put the ribbon cable in, then removed it before it turned off again. It's a place to start.
(03-16-2020, 12:32 AM)aaspectre Wrote: Yeah, it appears stuck in the on position. So I just put the ribbon cable in, then removed it before it turned off again. It's a place to start.
If you needs replacement, please contact sales@pine64.org and they are quote you accordingly.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,460 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook64 Pro doesn't power on andrea_from_italy 9 9,484 03-20-2025, 10:07 AM
  Keyboard issue j0rs 3 5,728 01-20-2025, 07:03 AM
  broken tow-boot hashkeeper 1 4,665 12-25-2024, 10:12 PM
Last Post: jessipinkman
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,963 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,205 11-25-2024, 03:42 PM
  Lockable-until-power-cycle persistent storage Melab 0 2,797 09-17-2023, 08:51 PM
Last Post: Melab
  Dead Pinebook Pro Keyboard Keys calinb 2 4,566 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 3,082 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 2,742 03-14-2023, 09:53 AM
Last Post: Bram
