Pinebook pro will not run a long stress test of OpenCL
Summary:
  • A stress test of SGEMM (matrix multiplication) using OpenCL will slow down after 150 iterationbs.
    • Details:
      • Test is running fine during the first 100 iterations (multiply two matrix of 512 x 512). It will slow down to 1/2 speed after about 150 iterations, and will slow down farther to about 1/4 speed after 200 iterations, etc.
      • Note: test is running fine if sleeping for 20 seconds after every 100 iterations
Question:
  • Do the Pinebook pro GPU has a hardware problem (ex: over heating) that prevent running a long OpenCL stress test?
Details:
  1. Pinebook pro setup highlights:
    1. Ubuntu 18.04 64bit (based on the root file system from: https://github.com/ayufan-rock64/linux-b...m64.img.xz)
    2. Compiler: gcc 8.3
    3. OpenCL 1.2 (wget --timestamp https://github.com/rockchip-linux/rk-roo..._arm64.deb)
    4. ARM Compute Library 19.11.1 (native compile of sources from https://github.com/arm-software/ComputeLibrary)
  2. [size=undefined]OpenCL is verified with:[/size]
  3. [size=undefined]Stress test:[/size]
    • SGEMM (matrix multiplication) using OpenCL of the ARM Compute Library 19.11.1 - the test code is appended below
// Example code is based on: // * https://github.com/ctuning/ck-math/tree/master/program/acl-sgemm-opencl-example // // #ifndef ARM_COMPUTE_CL /* Needed by Utils.cpp to handle OpenCL exceptions properly */ // #error "This example needs to be built with -DARM_COMPUTE_CL" // #endif /* ARM_COMPUTE_CL */ #include <arm_compute/core/Types.h> #include <arm_compute/core/Helpers.h> #include <arm_compute/core/ITensor.h> #include "arm_compute/core/CL/CLKernelLibrary.h" #include <arm_compute/runtime/Tensor.h> #include "arm_compute/runtime/CL/CLFunctions.h" #include "arm_compute/runtime/CL/CLScheduler.h" #include <cstdlib> #include <cstring> #include <fstream> #include <iostream> #include <cctype> #include <cerrno> #include <iomanip> #include <string> #include <sys/time.h> using namespace arm_compute; // (MM, MN, MK) can be override from compiler options #ifndef MM #define MM 512 #endif #ifndef MN #define MN 512 #endif #ifndef MK #define MK 512 #endif int main(void) {  long num_repetitions=1;  struct timeval before, after;  unsigned int m=MM;  unsigned int n=MN;  unsigned int k=MK;  if (getenv("NUM_REPETITIONS")!=NULL) num_repetitions=atol(getenv("NUM_REPETITIONS"));  if (getenv("MM")!=NULL) m=atol(getenv("MM"));  if (getenv("MN")!=NULL) n=atol(getenv("MN"));  if (getenv("MK")!=NULL) k=atol(getenv("MK"));  printf("NUM_REPETITIONS = %lu\n", num_repetitions);  printf("m = %u\n", m);  printf("n = %u\n", n);  printf("k = %u\n", k);  TensorShape AShape(k,m);  TensorShape BShape(n,k);  TensorShape OShape(n,m);  CLTensor ATensor;  CLTensor BTensor;  CLTensor OTensor;  CLScheduler::get().default_init();  ATensor.allocator()->init(TensorInfo(AShape,Format::F32));  BTensor.allocator()->init(TensorInfo(BShape,Format::F32));  OTensor.allocator()->init(TensorInfo(OShape,Format::F32));  CLGEMM gemm;  gemm.configure(&ATensor, &BTensor, NULL, &OTensor, 2.0f, 2.0f);  ATensor.allocator()->allocate();  BTensor.allocator()->allocate();  OTensor.allocator()->allocate();  gettimeofday(&before, NULL);  for(int r = 0; r < num_repetitions; ++r) {    gemm.run();    CLScheduler::get().sync();  }  gettimeofday(&after, NULL);  double total_time = (after.tv_sec - before.tv_sec) + 1e-6*(after.tv_usec - before.tv_usec);    double flops = 2.0*m*n*k;  double gflops = 1e-9 * flops;  double avg_time = total_time / num_repetitions;  double avg_gflops_per_sec = gflops / avg_time;  printf("M = %u\nN = %u\nK = %u\n", m, n, k);  printf("TIME_TOTAL = %lf\n", total_time);  printf("TIME_AVG = %lf\n", avg_time);  printf("GFLOPS_AVG = %lf\n", avg_gflops_per_sec);  printf("------------- CLBLAST-STYLE_OUTPUT\n");  printf("m = %u\nn = %u\nk = %u\n", m, n, k);  printf("ms_1 = %lf\n", avg_time*1000);  printf("GFLOPS_1 = %lf\n", avg_gflops_per_sec);  return 0; }
(02-05-2020, 01:48 PM)gal_shalif Wrote: Do the Pinebook pro GPU has a hardware problem (ex: over heating) that prevent running a long OpenCL stress test?
Nobody was stressing the gpu as much as you, yet.
Perhaps start with the usual suspects:
Display journal logs in real-time
$ journalctl -f
The kernel includes a thermal driver, maybe it's print something to dmesg?
$ dmesg
Then you can look at the cpu and gpu temperatures. If you don't find a gui, you can look at the sysfs attributes. They might vary depending on the kernel. Here from a modern 5.5 kernel
debian:/sys/class/thermal$ cat thermal_zone0/hwmon?/name  cpu debian:/sys/class/thermal$ cat thermal_zone1/hwmon?/name  gpu
cat these values in a loop for real-time updates
debian:/sys/class/thermal$ cat thermal_zone0/hwmon?/temp1_input  25000 debian:/sys/class/thermal$ cat thermal_zone1/hwmon?/temp1_input  25000
Let us know your findings.
  Boot Order in Pinebook Pro food 14 19,354 11-10-2026, 08:39 PM
Last Post: noahclark
  Window Maker Live for Pinebook Pro vajak 9 6,595 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,280 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,719 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,799 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,549 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,858 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,424 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,663 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 164,974 12-08-2023, 11:25 PM
