(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#71
Did you try ethernet connection?
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
#72
No. Actually my router is in another room. I'm connecting Pine64 to my TV. I just figured the WiFi/Bluetooth board that came with my Pine board would pick up my network. The Wifi works fine with the Remix OS image.
#73
Hi All
Can someone  know how to match USB port to usb serial device.
I can't  find /dev/ttyUSBX
Regards
Tomek
#74
I need a little bit of clarification.
I downloaded the Debian Base image because I don't want a desktop interface (I would use it as a server).
How can I install java on it, should I have downloaded another image?
And how can I change the root filesystem, I don't understand that part either.
#75
simply apt-get install teh java package you would like
Cheers Big Grin
#76
(04-16-2016, 10:07 AM)lenny.raposo Wrote: simply apt-get install teh java package you would like
I get this when using: sudo apt-get install java:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package java
#77
The packages for Java will be named openjdk*. You can search for the versions via
aptitude search openjdk
I have installed openjdk-8-jre for the runtime only. If you need development, you just install the openjdk-8-jdk package.
E.g. minecraft runs well with jre only...
Have fun
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
#78
(04-16-2016, 11:55 AM)androsch Wrote: The packages for Java will be named openjdk*. You can search for the versions via
Have fun
I would like to user oracle java, there is even an ARM version of it but I don't know how to install it.
I know it's working on the rPi, how about the Pine64?
p.s: I only found openjdk-7 but that's probably good for now, thanks
#79
What sources in /etc/apt/sources.list are you using?
#80
(04-16-2016, 12:37 PM)androsch Wrote: What sources in /etc/apt/sources.list are you using?
deb http://ftp.us.debian.org/debian jessie main
  Debian installer on Pine A64+ but no hdmi mrwick 1 8,951 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,196 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,418 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 16,612 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 164,510 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,294 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,645 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 10,850 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 20,833 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 20,826 05-09-2018, 09:07 PM
Last Post: pfeerick
