The usage/access of the SPI flash
So, reading through the wiki, if my reading comprehension is where it should be, it appears to me that is
1. the RK3399 searches to boot from SPI flash first
2. there is spi flash presentt
3. it is unused or it's use is undocumented
I ask, because this would be the obvious place for a more complex bootloader (i.e. coreboot) instead of relying on the hardcoded boot order, potentially adding support for SSD boot without any hacky drive leapfrogging stuff.
Apologies if this has been talked about before, couldn't quite find anything though.
EDIT: I was so eager to be helpful I didn't even look at the pinned posts, lol.
The Pinebook Pro seems to be the higher end, (highest end at the time designed?), ARM laptop that is not designed as a Chromebook. As such, it's gotten a bit more attention than previous works, (the Pinebook 11" & 14", as well as others). So we may start seeing more work in regards to making a more feature rich boot system.
At present though, we don't have keyboard or display drivers usable from embedded code, (aka ROM/Flash code). That's what I think is needed after NVMe boot.
Since it's easier to use the eMMC or SD card for development, it may be 6 months or a year before we see interactive and feature rich boot code.
Edit: I also meant ARM laptops built for MS-Windows may be higher spec'ed.
Arwen Evenstar
Princess of Rivendale
lol, I forget those are even things that need to be considered. Coreboot with hardware that gets support is just check the right boxes on nconfig and then make, getting it to that point is way beyond me though. I am very excited for when (and I do think it's a matter of when) it gets to that point. It seemed like this laptop was my only option for a specific niche, which I don't think is that obscure, so I'm sure it will be massive.
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 106,762 11-20-2023, 06:22 PM
  No boot after Manjaro flash PBcurry 14 16,908 10-03-2022, 08:33 PM
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 343,527 09-27-2022, 07:41 AM
Last Post: olyavi
  How can I flash SPI so that I can boot from NVMe? codingpanic 5 11,962 08-24-2021, 05:07 AM
Last Post: codingpanic
  First access denied IMSAI8080 3 6,808 06-07-2021, 01:08 PM
Question erase spi flash aiminick 1 4,715 04-07-2021, 06:50 AM
  Booting to sdcard stopped working after emmc flash techiedog 3 7,458 12-31-2020, 06:30 PM
Last Post: Anarethos
  Flash non-bootable eMMC? midnightcheese 2 4,855 12-24-2020, 08:01 AM
Last Post: midnightcheese
  Private Internet Access VPN on Pinebook Pro 11Eleven 13 26,278 10-27-2020, 05:35 PM
Last Post: AronShap
  U-Boot on SPI flash - discussion Arwen 20 41,102 09-16-2020, 08:20 AM
Last Post: hmuller
