(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#61
(04-11-2016, 12:29 AM)umiddelb Wrote:
(04-10-2016, 07:58 PM)lenny.raposo Wrote: I have added the md5 hash for all images
I'd recommend sha256, md5 is known to be broken.
WinDiskImager supports MD5-hash directly in its dialogue, so MD5 seems to be the better choice.
(04-11-2016, 03:48 AM)pictus Wrote: Thanks for your Images, i used the xfce version and installed a small smb server for testing.
Tried to upload a 900mb file to the Pine (32gb Card installed) but it tells me, that i don´t have enough free space - only 300mb free space?!
Did you expand your root_fs? Even using a 128GB Card directly after decompressing the image only shows a 4GB Partition! Can you verify the free space on the SMB-server folder on the pine itself?
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
#62
Wrapped up my MicroSD card testing, got my solar charger and battery ready, and thanks to these images I'm ready to give my solar-powered desktop quasi-replacement a first shot tonight. Thanks for clearing the 2 GB hurdle so quickly!
#63
Thanks for the work. Have been successfully using the LXDE image for the past 5 days without issue. Looking forward to GPU drivers eventually.
#64
(04-11-2016, 04:39 AM)androsch Wrote: Did you expand your root_fs? Even using a 128GB Card directly after decompressing the image only shows a 4GB Partition! Can you verify the free space on the SMB-server folder on the pine itself?
No i didnt, how do i do that? I tried to follow the instructions here but i have no linux to create a ext4 partition. I have an MacBook with SSH access to the Pine.
#65
With my images and longsleep's images (which I base my work on to allow for consistency) there are scripts to do it included.
first I would run the following
pine64_update_uboot.sh
then
pine64_update_kernel.sh
then
resize_rootfs.sh
followed by a reboot Wink
the first 2 scripts updates u-boot (where the kernel is loaded) and updates the kernel modules (libraries/etc)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
#66
New Entry Into First Post Everyone. Also I am currently working on a PulseAudio solution and working on Mali 2d/3D acceleration.
Cheers Big Grin
#67
I'll point to my web site entry that describes how I got my Pine64+, 2GB, now called "abel",  up and running...
http://linuxdatabases.info/info/abel.html
I didn't use anyone's scripts; I pulled the root filesystems from the torrents here (specifically, the LXDE one), added to bootloader per umiddelb, and turned that into an initial image for my SD card.
I was somewhat surprised that it worked the first time, gotta pass kudos on that!!!
#68
I just installed LXDE Desktop image. Everything seems to work fine except the WiFi. It can't find any networks. Am I doing something wrong? I'm also new to Linux.
run the following commands
sudo -i
followed by
followed by
and if you haven't expanded your rootfs
resize_rootfs.sh
reboot
Cheers Big Grin
#70
I can't run the uboot or the kernel command without internet access. It says: curl: (6) could not resolve host: www.stdin.xyz
  Debian installer on Pine A64+ but no hdmi mrwick 1 9,251 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,838 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 5,681 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 17,172 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 167,400 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 8,566 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 7,923 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,297 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,481 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 21,485 05-09-2018, 09:07 PM
Last Post: pfeerick
Users browsing this thread: 7 Guest(s)
