Any word about Android builds?
#21
I got Android on there by using dd with the mrfixit image. It took several attempts to get my system booted, it kept going into the recovery mode. Now everything is up and running, which is a good start; no gapps are installed with the pinebook pro image I used. I need to look up how to root this device.
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
#22
Which Android? I got the 7.1 running well but haven't gotten 8 to boot yet.
#23
It is the one from the wiki. 7.1
I'm using fdroid for apps
#24
Does it have windows? Any chance you can share a screenshot?
#25
(11-11-2019, 03:25 AM)brent.thierens Wrote: Does it have windows? Any chance you can share a screenshot?
You can enable freeform desktop pretty easily with it. Unlock developer settings, check "Allow all apps to be resizable," open a terminal (or use a computer with ADB) and drop in a couple of commands. Here's a quick guide for anyone interested.
#26
I would like to add Android to eMMC for multiboot, but I cannot read the SD card partitions after installing Android to SD in Linux, seems like there is just one unrecognized partition. Strange, that it boots and works.
#27
Does anyone else have "Prepare IDB Fail" when attempting to flash with RKTools?
.png   Annotation 2019-11-16 155411.png (Size: 18.11 KB / Downloads: 725)
#28
(11-16-2019, 02:53 PM)DarkestSpawn Wrote: Does anyone else have "Prepare IDB Fail" when attempting to flash with RKTools?
You got farther than me, mine wouldn't get that far using this tool.
#29
is there a way to get the Google Play Services and Store on the 7.1 Image?
#30
Yes, if you look through the RockPro64 forums, there is a post about how to install Play Store. You'll need another computer to adb push the apps.
  Google on Android? KC9UDX 21 48,366 03-17-2023, 11:35 AM
  No Android build working! pin 60 139,583 07-03-2021, 06:08 PM
Last Post: justiceankomah
  MD5 On Android jaysistar 0 4,994 03-14-2020, 08:38 AM
Last Post: jaysistar
  Arguments for android support metcalsr 20 49,985 02-08-2020, 12:12 PM
Last Post: Idaho
Exclamation All android buillds on wiki for Microsd missing GPT? TDC_PBP 14 35,265 01-31-2020, 11:22 PM
  Flashing Updated U-Boot on Android tophneal 6 17,212 01-16-2020, 06:05 AM
