Manjaro ARM for Pinebook
#61
(07-19-2019, 05:05 PM)Luke Wrote:
(07-19-2019, 09:00 AM)rckt Wrote: Trying to install 19.06 on 1080P and getting stuck on boot from sd card.
Here's what I see: https://imgur.com/3VoEyI5
ping Strit in the chats or ask in the manjaro forum.
[edit] looks like other users have also experienced this, but only occasionally.
I have been chatting to Strit & Dodge in the Manjaro forum and currently Strit was laughing as he is checking for 5.3 release several times a day.
They have a number of Arm Socs wanting Lima and when 5.3-Rc1 is out it will prob be a matter of hours.
But they are really great, open for chat devs and you should get on the Manjaro forums as they would prob appreciate any feedback.
https://forum.manjaro.org/t/manjaro-arm-...ased/91858
If haven't worked out if the merge window finished and its likely to day or the merge window finishes and its Monday.
Lima is lagging behind Panfrost slightly and prob might be in same situation where Mesa 19.2.0-devel works much better, but that might be just Panfrost as think much is Alyssia and her work with Panfrost/Wayland/Gnome.
#62
Agreed, the Manjaro devs are a great.
#63
Probably worth to mention - Manjaro got updated to 19.08
https://forum.manjaro.org/t/manjaro-arm-...ased/99031
It supports Pinebook, and also have an EMMC installation images which contains nice installation script.
The only problem is that I tried to install both XFCE and i3 EMMC versions, and I'm getting "No space left on device" errors during XZ img extraction.
I tried that on two different microSD cards, 16 and 32GB, flashed by Etcher. No difference
1080p Pinebook
Does anyone else tested these images?
#64
(08-29-2019, 08:36 AM)fitter Wrote: Probably worth to mention - Manjaro got updated to 19.08
1080p Pinebook
You should let Strit know about this in the 19.08 announcement thread. Doesn't look like anyone's reported these issues there.
#65
Perhaps, I'm completely outdated in the current devs but i've tried to play FHD video on manjaro with:
mvp -vo drm video.avi
And it works great!
Video starts in fullscreen and run smoothly. Big Grin
I didn't check with a lot of file but for me it is a great improvement !
#66
1080p Pinebook
Yep, I just wanted to ask community if someone had similar issue before bothering devs.
I wrote Strit, he updated the images, the installation goes now fine (I tested it with XFCE image).
#67
Exclamation
We've now Full HD videos at the Manjaro ARM - KDE Edition for the Pinebook
#68
(10-23-2019, 02:55 AM)schinfo Wrote: We've now Full HD videos at the Manjaro ARM - KDE Edition for the Pinebook
Can you explain in more details please?
You mean by using mpv?
How does HW acceleration work exactly on the Pinebook?
I know how to setup Arch Linux with HW acceleration for Intel graphics, but I have no idea how it works for the Pinebook. There supposedly is a connection with the kernel version? But what driver?
A setup guide for the Pinebook would be really nice. It would be great if it would be possible to run Gnome on the Pinebook and have decent YouTube playback (and if only with a plugin forwarding video playback to mpv).
And what about (ungoogled-) Chromium, which can be complied with HW acceleration (in contrast to Firefox, which still doesn't support it)?
#69
He probably mentioned new released Manjaro 19.10 https://forum.manjaro.org/t/manjaro-arm-...sed/107677
Allwinner A64 is getting mainline HW video decoding features thanks to the project Cedrus. I will test it when I find some time
#70
I have pinebook 1080p with KDE Neon i just flash emmc card by etcher with Manjaro 19.12 since it does not boot from emmc i decide to dd boot but still no luck. I cannot boot at all, so i should disasembler the panel an trying remove sd card somehow?
  DietPi OS for Pinebook MichaIng 5 16,767 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,441 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 102,980 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,795 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,386 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,409 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,337 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,571 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,277 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,408 01-20-2021, 11:18 AM
