11-05-2019, 06:23 PM
Ditto on the Firefox crapout on VPN switch
(11-05-2019, 03:49 PM)rick1959 Wrote:(11-05-2019, 08:49 AM)I’m richfm Wrote:I noticed putting processor speed to performance helps a lot... That worked, Rick! I turned up the processor speed to 2.02 GHz. Thanks you so much. I was on the point of of turning my PBP into a trivet! Internet speed is better.I thought the processor speed was dynamically set to save power? I had it on "interactive" whatever that means.
11-05-2019, 10:14 PM
(11-05-2019, 09:47 PM)richfm Wrote:YAY!! Good show!!(11-05-2019, 03:49 PM)rick1959 Wrote:(11-05-2019, 08:49 AM)I’m richfm Wrote:I noticed putting processor speed to performance helps a lot... Perhaps down the road, software will better compliment the hardware. Some work to be done before "throttling up" may not be necessary though, at this point Enjoy your new "trivet"!! :-)
11-06-2019, 07:09 AM
(11-05-2019, 02:04 PM)richfm Wrote: The at (@) symbol is above the single quote mark (') key. Pressing shift with that key (') is supposed to write the @ but it writes the double quote Mark (") instead . I don't mind having @ be shift-2 where I am used to it being. The problem is that then the keyboard is physically labeled wrong. That would need to be fixed with a sticker, replacement key cap, or some other hardware solution. (11-05-2019, 10:14 PM)rick1959 Wrote:Although the wifi speed has improved somewhat with the increased CPU speed, web pages still load much slower than my other laptops. The connection information is still a quarter to half less in the PBP than in the other laptops that I use. I knew that the PBP was a work in process when I bought it but I did expect a machine! that could at least surf the internet, download email, etc. This is a disappointment.(11-05-2019, 09:47 PM)richfm Wrote:YAY!! Good show!!(11-05-2019, 03:49 PM)rick1959 Wrote:(11-05-2019, 08:49 AM)I’m richfm Wrote:I noticed putting processor speed to performance helps a lot... I'm running Ubuntu with Mate now. I'm wondering if changing to bionic lxde would fix this problem? Any suggestions? (I booted biopic lode from microsd and could not connect to my gateway. Starting to think I got a device with wifi hardware problems). Question. Is there any actual tech support for these devices?
11-06-2019, 12:02 PM
Just wanted to thank everyone reporting their experience with the pinebook pro. I was considering buying the laptop and using it when travelling. I need something light, not especially fast and running Linux (or BSD) instead ChromeOS or android.
By the sound of it, the pinebook pro is very impressive build-wise but the software support has a long way to go. I think this highlights the challenges independent hardware makers face when trying to create a product that could potentially rival an offering by an established industry player. As a consumer you have no choice but to jump into the clutches of the Lenovos of the world. Having something that "just works" is a product of countless hours of labour and well-established processes (thanks to first making a lot of mistakes). Good for everyone contributing to this very exciting project!
11-06-2019, 12:03 PM
(11-06-2019, 09:20 AM)richfm Wrote:I think that answers will be more "community supported" than some tech person with a dedicated job.(11-05-2019, 10:14 PM)rick1959 Wrote:Although the wifi speed has improved somewhat with the increased CPU speed, web pages still load much slower than my other laptops. The connection information is still a quarter to half less in the PBP than in the other laptops that I use. I knew that the PBP was a work in process when I bought it but I did expect a machine! that could at least surf the internet, download email, etc. This is a disappointment.(11-05-2019, 09:47 PM)richfm Wrote:YAY!! Good show!!(11-05-2019, 03:49 PM)rick1959 Wrote:(11-05-2019, 08:49 AM)I’m richfm Wrote:I noticed putting processor speed to performance helps a lot... And to be more specific, we're the test drivers.. So with that comes all of us working together for answers. WiFi is not a strong point with these devices, BUT there's been discussion earlier of software improvements to make WiFi better. We'll see. In the meantime, please read through the forum posts and you may get some info that will help with some of this. And to any question that starts out with "Should I try..." ABSOLUTELY!!! As we're all learning here, anything that helps move us toward greater enlightenment has gotta be a plus....And maybe, get us closer to a Pinebook Pro smooth operation :-) (11-06-2019, 12:03 PM)rick1959 Wrote:(11-06-2019, 09:20 AM)richfm Wrote:I think that answers will be more "community supported" than some tech person with a dedicated job.(11-05-2019, 10:14 PM)rick1959 Wrote:Although the wifi speed has improved somewhat with the increased CPU speed, web pages still load much slower than my other laptops. The connection information is still a quarter to half less in the PBP than in the other laptops that I use. I knew that the PBP was a work in process when I bought it but I did expect a machine! that could at least surf the internet, download email, etc. This is a disappointment.(11-05-2019, 09:47 PM)richfm Wrote:YAY!! Good show!!(11-05-2019, 03:49 PM)rick1959 Wrote: I noticed putting processor speed to performance helps a lot... Rick, thanks for your reply. I understand this is a community project but what if my wifi problem is a hardware problem? I've tried everything everyone has suggested as you can see from my posts but it's almost impossible to use the PVP with any internet application. I've seen no one else here describing this problem so I'm assuming my PVP problem is unique. It's not that wifi is a weak point, it's practically unusable. I'm used to working with Linux on arm chromebooks so know something about the architecture. I'm flashing the original debian img file to the PVP now so we'll see. However it's been a week since I received the device and have not been able to get it working satisfactorily yet. Sorry to be such a downer here but I think my problem may be a hardware issue. Have contacted pine64.org tech support.
11-06-2019, 01:53 PM
(11-06-2019, 01:41 PM)richfm Wrote:You're welcome!(11-06-2019, 12:03 PM)rick1959 Wrote:(11-06-2019, 09:20 AM)richfm Wrote:I think that answers will be more "community supported" than some tech person with a dedicated job.(11-05-2019, 10:14 PM)rick1959 Wrote:Although the wifi speed has improved somewhat with the increased CPU speed, web pages still load much slower than my other laptops. The connection information is still a quarter to half less in the PBP than in the other laptops that I use. I knew that the PBP was a work in process when I bought it but I did expect a machine! that could at least surf the internet, download email, etc. This is a disappointment.(11-05-2019, 09:47 PM)richfm Wrote: That worked, Rick! I turned up the processor speed to 2.02 GHz. Thanks you so much. I was on the point of of turning my PBP into a trivet! Internet speed is better.I thought the processor speed was dynamically set to save power? I had it on "interactive" whatever that means.YAY!! Good show!! Clearly, there's a chance you could of got a klinker piece of hardware. If it were me, I'd open a support request. From the pine64.org "start" page, along the top is tab listed as "Order Support". Click on it and submit a ticket (did I miss you've already done this?) for the problem. I, for one, will be interested to see how that plays out. If you're dissatisfied with that, perhaps a PM to an administrator, founder or someone like Luke might help it along.... There's absolutely no doubt that, despite best efforts, a hardware glitch could get through. You'll be helping not only yourself, but the rest of us see how the support function works here... Does that help? :-)
11-06-2019, 02:02 PM
(11-06-2019, 01:53 PM)rick1959 Wrote:(11-06-2019, 01:41 PM)richfm Wrote:You're welcome!(11-06-2019, 12:03 PM)rick1959 Wrote:(11-06-2019, 09:20 AM)richfm Wrote:I think that answers will be more "community supported" than some tech person with a dedicated job.(11-05-2019, 10:14 PM)rick1959 Wrote: YAY!! Good show!!Although the wifi speed has improved somewhat with the increased CPU speed, web pages still load much slower than my other laptops. The connection information is still a quarter to half less in the PBP than in the other laptops that I use. I knew that the PBP was a work in process when I bought it but I did expect a machine! that could at least surf the internet, download email, etc. This is a disappointment. Yes it does help, thanks. I've contacted tech support. I'll keep you posted. |
| Updated Pinebook Pro? | tantamount | 2 | 2,259 |
06-20-2026, 10:14 AM Last Post: tantamount |
| Pinebook pro bricked? | michaelmoua | 4 | 7,995 |
05-26-2026, 02:20 AM Last Post: Anthona |
Finally got Kali working on my Pinebook Pro! | qingss0 | 0 | 1,736 |
04-04-2026, 08:00 AM Last Post: qingss0 |
| dead Pinebook - help please | RicTor | 3 | 3,304 |
03-26-2026, 04:22 PM Last Post: williamcorlin |
| Pinebook problem | meghancordo | 2 | 6,745 |
03-18-2026, 08:58 AM Last Post: RicTor |
| Pinebook Pro in EU for Sale - €90 | jan_vdk | 5 | 10,599 |
02-09-2026, 12:50 AM Last Post: Anthona |
| Pinebook Pro for sale | rfm83 | 0 | 1,920 |
11-08-2025, 09:22 AM Last Post: rfm83 |
Full desktop Surfing and Absolute Privacy on the pinebook? | Www | 1 | 8,765 |
08-02-2025, 08:55 PM Last Post: KC9UDX |
Printing and scanning documents with pinebook? | Www | 0 | 5,165 |
06-28-2025, 01:25 AM Last Post: Www |
| Use SD to install new OS over pinebook debian | Rudy558 | 10 | 29,746 |
03-09-2025, 11:17 AM Last Post: davisthomas |
