Pinebook Pro?
(07-28-2019, 08:05 AM)fire219 Wrote:
(07-28-2019, 06:47 AM)cocozozo Wrote: Just confirming if the power supplies for the pinebook pro will be "switching"?  I'm wanting to order for use in Australia. Currently I see USA and EU adapters only. Can I simply order either USA or EU and use a travel adapter or will you be offering other connections (e.g. AU).
Many thanks
Yes, all the power adapters can run on any line voltage. There also is a AU plug available with this one: https://store.pine64.org/?product=rock64...uk-us-plug
Hi Fire219,
Just double checking your post out of pure cautiousness, are you saying that the power supply you've linked will work with the Pinebook Pro (it seems like it should given it's fine for the Pinebook and they seem to have the same set up from a battery/power perspective)?
I live in Australia and I've been fortunate enough to get into the first batch of 100. I've ordered with the US power supply but will buy one of these now, so I don't have to deal with travel adapters.
Thanks!
Many thanks
Hi Fire219,
Thanks!
Yes, the Pinebook, Rock64, and Pinebook Pro all use the same 5V 3A power supply.
Many thanks
Hi Fire219,
Thanks!
Thanks Fire219, I appreciate your quick response!
Is there a reason the CPU is clocked at 1.8 instead of 2.0 GHz? According to Rockchip, the chip can be clocked up to 2.0 GHz.
I found a thread on this forum about overclocking, but will we able to change the clock speed without recompiling the kernel?
Heat and battery life ?
(09-25-2019, 02:38 PM)Kochise Wrote: Heat and battery life ?
Almost certainly these. The chip is only passively cooled -- with the case acting as heat sink, so consider how hot you want the thing in your lap. And slower clock also uses less power, so you get a longer battery life. It may be possible to undervolt it, but I don't know how you might go about doing that.
Sent from my moto x4 using Tapatalk
The clock speed is dynamic, so it would be interested to have the chip running at max power for short bursts, e.g. when firing up applications to feel a little more snappy. For long periods this is indeed not what you want.
(03-28-2019, 06:47 AM)ivanB1975 Wrote: I read that the pinebook pro will have 4GB of RAM. Would not be better to have at least 8 if not 16? I am a software developer and I use a lot local containers.
I also do some light to moderate programming. I have a small Penguinized Chromebook with 4GB of RAM and I'm not sure if I've ver seen it go past 2.5 gigs of usage.
Personally I do view 4GB as a compromise. It's low enough that I expect to feel the lack of RAM from time to time and may have to tune things a little more than usual.
That's said it's a compromise I'm very happy to make since it is a compromise based on the fact that, while the RK3399 is a terrific chip for products like this, unfortunately it isn't capable of talking to more than 4GB of RAM. There's simply not enough choice of chips in this space (and price point) to build something without compromise somewhere.
It may be a compromise, but I have found that it has worked good for me.
I have upgraded to 4gb on the machines I have that can be upgraded, but I have not ever found that limiting for me, personally.
The newer solid state drives have been the biggest game changer "for me."
( I understand some people need more, some for real needs, some for bragging rights. )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 273 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 964 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,790 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 8,047 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 721 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,318 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,292 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,025 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 25,803 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,103 02-05-2025, 03:56 AM
Last Post: waylonwesley
