Dual image uboot
We having been discussing uboot on SPI as a way to get bootable PCIe NVMe drives. Yet the consensus is that the SPI is for a version of uboot, (or other firmware), that is quite stable.
But, we can also do some interesting things for recovery. If uboot is not that big, perhaps we can have 2 versions, with a tiny bit of code to select the most current, unless a special key is held down. Then it uses the prior release. That may help prevent some of the bricking of the PBP that has been disscused for new, but faulty firmware.
This could apply to both eMMC and SPI., though eMMC is an easier un-brick than SPI.
Just an idea.
Arwen Evenstar
Princess of Rivendale
It has to be programmed and put somewhere, given that keyboard is connected via USB it means a ton of code to support that.
So. I would say: it is unlikely. I would rather assume that SPI happens first, that will allow multi-boot by default.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
radxa has some code in their repo to support spi -> nvme boot for rk3399
repository: https://github.com/radxa/u-boot.git
branch : rk3399-pie-gms-express-baseline
Original post https://forum.radxa.com/t/spi-nvme-booti...a/1306/161
(10-11-2019, 10:11 AM)ayufan Wrote: It has to be programmed and put somewhere, given that keyboard is connected via USB it means a ton of code to support that.
Thanks, point taken. Using the keyboard to select alternate SPI boot image would require USB HID support. Too much added work.
When time permits, I'll take a look at alternatives.
Arwen Evenstar
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 2,883 01-03-2026, 07:09 AM
Last Post: qingss0
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,152 11-25-2024, 03:42 PM
  uboot wont boot to SD card after upgrade jbradley419 7 9,749 01-19-2024, 02:29 PM
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 5,498 09-19-2023, 08:48 AM
Last Post: dachalife
  Pinebook Pro won't turn on after flashing image Idaho 2 4,253 02-21-2023, 02:31 PM
Last Post: Idaho
  Wiped EMMC, forgot do write new image, won't recognize EMMC zeno 4 9,213 05-11-2021, 01:53 PM
  Latest PBP Factory Image? calinb 2 6,503 05-10-2021, 03:24 PM
Last Post: calinb
Brick Bricked? Pinebook Pro using Uboot-pbp hanmorten 8 17,277 06-24-2020, 10:33 AM
Last Post: hanmorten
  emmc image will not flash Uturn 9 20,612 04-04-2020, 07:02 AM
Last Post: jiyong
  Flashing image to EMMC Styles 12 21,897 01-17-2020, 08:48 AM
