issue with kodi freezing randomly
HI there,
I have the NAS case with the RP64. I installed the latest MrFixit image on it and managed to install/setup:
- samba (to have a network drive)
- Rsync (to backup the network drive)
- remove pulseaudio to avoid random freeze as it's currently an unresolved issue)
- install Kodi to have a media center (to read the video / music / photos I save on the HDD)
the issue is with Kodi as when I run it I get random freeze (where nothing is working anymore (no ssh, no network access, image on screen is frozen). The freeze has the same behavior as the issue caused by pulseaudio.
Would anyone have a working kodi (other than the specific distro available)?
What has kodi in common with pulse audio? this issue might be linked with the pulse audio issue somehow and I would like to resolve it if possible.
Thanks for anyone reading / helping!
Small update on this:
- I'm sadly not able to capture UART output as I don't have the required equipment for it Sad
- I'm using the Desktop image from MrFixit2001
- When I run "top" to get details on Ram & CPU and check the temperature of the board there is nothing visibly problematic displayed before the freeze. Ram, cpu & temp are all stable and low.
- I got myself a UART connector to see if anything would come out on the serial port but nothing come out sadly.
- I tested without the PCIe and Kodi work with no freeze then
It look like the issue with pulseaudio freezing the board if the PCIe card is connected. I'm not sure what Kodi and pulseaudio have in common though :S
Today, I tested the mrfixit desktop build + Kodi. With a X540 10gig copper Intel NIC (detected via lspci -vvv but not network tested), Kodi launched without an issue. If I end up getting a SATA card I will update here.
  OMV to Kodi Streaming Issues cogito808 12 28,217 05-25-2021, 08:30 AM
Last Post: helpmerock
  Debian, Kodi and the Spotify plugin. Pineapple 1 5,105 10-14-2019, 10:02 PM
Last Post: SBCraok
  Linux distro that will work with Kodi? SBCraok 9 20,659 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
Exclamation eMMC boot issue jwillmer 0 3,379 07-19-2019, 03:16 PM
Last Post: jwillmer
  Does anyone have kodi working? blahblahblah 6 12,978 07-19-2019, 08:09 AM
Last Post: PackElend
  computelibrary build issue with latest ubuntu 18 image rahulsharma 0 3,050 07-08-2019, 09:25 AM
Last Post: rahulsharma
Lightbulb How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI fosf0r 14 30,338 12-17-2018, 11:57 AM
Last Post: fosf0r
  super fast desktop experience, but youtube issue frewind 13 29,336 11-17-2018, 07:32 PM
Last Post: jwcolby54
  Issue with hwmon - Fan Stop after logout-Login tuxd3v 1 4,733 09-22-2018, 08:49 AM
Last Post: tuxd3v
  RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous) JeffD 23 48,454 09-16-2018, 12:08 AM
Last Post: romtorwator
