Does anyone have kodi working?
I just got my rockpro64 and I am trying to get it setup to run kodi and retroarch.  I have it running on the bionic-lxde-rockpro64-0.7.9-1067-arm64.img.xz image.  But I have no sound in kodi.  Sound works in mplayer after removing pulseaudio, but it gives the "your system is too slow" warning when trying to play any 1080p videos.
(08-24-2018, 09:48 AM)blahblahblah Wrote: I just got my rockpro64 and I am trying to get it setup to run kodi and retroarch.  I have it running on the bionic-lxde-rockpro64-0.7.9-1067-arm64.img.xz image.  But I have no sound in kodi.  Sound works in mplayer after removing pulseaudio, but it gives the "your system is too slow" warning when trying to play any 1080p videos.
There is currently a dev working on both.
I got kodi installed a while back but I never actually tested the sound. I'll have another look at it.
I do have RetroPie going on it though, which uses Retroarch. Someone made a Rock64 fork and I just used that for my RockPro64... with a little persuasion. Unfortunately N64 emulation isn't working but most other things do.
@Pitcrawler - just wondering if the build you're using on the rockpro uses X11, wayland, or gbm?
If I go through
Early mainline images for RK3288, RK3328 and RK3399
feedback for test build LibreELEC-RK3328
some of the issues are resolved, aren't they?
furthermore there are images on https://libreelec.tv/downloads_new/rockchip/
If I go through
They are all resolved ... there are official LibreELEC images for the RK3399 - including the RockPro64. There is Recalbox (EmulationStation+ KODI) for the RPro64, as well as ORA, Batocerra,etc., You can run KODI with correct flags in the desktop builds too.
(07-19-2019, 08:07 AM)Luke Wrote: They are all resolved ... there are official LibreELEC images for the RK3399 - including the RockPro64. There is Recalbox (EmulationStation+ KODI) for the RPro64, as well as ORA, Batocerra,etc., You can run KODI with correct flags in the desktop builds too.
great
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,690 10-29-2021, 11:15 AM
Last Post: TRS-80
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 4,066 09-13-2021, 11:02 AM
Last Post: twilite
  OMV to Kodi Streaming Issues cogito808 12 28,076 05-25-2021, 08:30 AM
Last Post: helpmerock
  WiFi not working with PCIe SSD installed mikeD 0 2,990 05-25-2021, 07:48 AM
Last Post: mikeD
  Netflix with hardware acceleration not working Helium75 1 5,293 12-15-2019, 09:26 AM
Last Post: Helium75
  Debian, Kodi and the Spotify plugin. Pineapple 1 5,063 10-14-2019, 10:02 PM
Last Post: SBCraok
  Linux distro that will work with Kodi? SBCraok 9 20,574 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
  issue with kodi freezing randomly Slam 3 7,057 05-24-2019, 03:53 PM
Last Post: mknawabi
Lightbulb How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI fosf0r 14 30,186 12-17-2018, 11:57 AM
Last Post: fosf0r
  Tutorial: OpenCL 1.2 FULL_PROFILE Working( moved for Tutorials Section ) tuxd3v 0 2,720 11-06-2018, 12:46 PM
Last Post: tuxd3v
