02-05-2019, 04:38 PM
I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos.
Pinebook Pro?
02-05-2019, 05:08 PM
(02-05-2019, 04:38 PM)locoturko Wrote: I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos. I just checked and there is no arm64 packages for mint binaries... http://packages.linuxmint.com/list.php?release=Tessa
02-05-2019, 07:27 PM
(02-05-2019, 05:08 PM)evilbunny Wrote:(02-05-2019, 04:38 PM)locoturko Wrote: I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos. As a Mint user myself, I am going to guess that Mint has source packages as well, right? If so, it should be possible to just build each required package from source? I would love it if the Mint team had build's for Pinebook/Pinebook Pro, Ubuntu MATE would be nice, having Arch would also be a real treat.
02-05-2019, 07:42 PM
(02-05-2019, 07:27 PM)mzs.112000 Wrote: As a Mint user myself, I am going to guess that Mint has source packages as well, right? Just pointing out that it's not as simple as just pointing apt at a new repository. In the case of arm boards it's even messier because there is no bios to hook into for driving hardware, which why there is so many armbian images.
02-06-2019, 03:14 PM
(02-05-2019, 07:42 PM)evilbunny Wrote:(02-05-2019, 07:27 PM)mzs.112000 Wrote: As a Mint user myself, I am going to guess that Mint has source packages as well, right? I wonder why no one has came up with a standardized EFI system for ARM boards? There needs to be an EFI firmware with ports for the major ARM systems, ideally it should also have a user-acessible UI just like a regular computer/laptop. Then, that would eliminate the issue of having so many images for different boards or different board variants, since the EFI would provide a standardized HAL for OS to hook into.... Installing new OS on an ARM-based laptop, SBC or PC would be as simple as installing one on an Intel computer.
02-06-2019, 03:24 PM
Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared.
Will the PineTab adopt the same SD-Card preferential boot? Personally prefer this approach, makes distrohopping really easy.
[ PHP Developer | Pinebook 1G | About me ]
02-06-2019, 03:53 PM
(02-06-2019, 03:24 PM)soupbowl Wrote: Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared. Maybe they can use LibreBoot and Coreboot? https://www.coreboot.org/ https://libreboot.org/ Either one would make things way easier for Linux and BSD distros to support ARM devices and PCs.
02-06-2019, 04:53 PM
I'm here because of the PCMag article, and others. I have been waiting for something like the pinebook pro for a long, long time. Kudos to you folks for achieving what has apparently been impossible for other companies! I eagerly await the moment I can get my hands on one and get to the precious bits inside!
02-06-2019, 09:40 PM
Also eagerly awaiting the Pro. Heard about it from the same articles that are floating around. Very interested in a great combination of price and performance lab machine built for linux from the ground up. Following thread for updates.
| Updated Pinebook Pro? | tantamount | 2 | 716 |
Today, 10:14 AM Last Post: tantamount |
| Pinebook pro bricked? | michaelmoua | 4 | 6,306 |
05-26-2026, 02:20 AM Last Post: Anthona |
Finally got Kali working on my Pinebook Pro! | qingss0 | 0 | 824 |
04-04-2026, 08:00 AM Last Post: qingss0 |
| dead Pinebook - help please | RicTor | 3 | 1,829 |
03-26-2026, 04:22 PM Last Post: williamcorlin |
| Pinebook problem | meghancordo | 2 | 5,326 |
03-18-2026, 08:58 AM Last Post: RicTor |
| Pinebook Pro in EU for Sale - €90 | jan_vdk | 5 | 8,820 |
02-09-2026, 12:50 AM Last Post: Anthona |
| Pinebook Pro for sale | rfm83 | 0 | 1,059 |
11-08-2025, 09:22 AM Last Post: rfm83 |
Full desktop Surfing and Absolute Privacy on the pinebook? | Www | 1 | 7,695 |
08-02-2025, 08:55 PM Last Post: KC9UDX |
Printing and scanning documents with pinebook? | Www | 0 | 4,343 |
06-28-2025, 01:25 AM Last Post: Www |
| Use SD to install new OS over pinebook debian | Rudy558 | 10 | 27,024 |
03-09-2025, 11:17 AM Last Post: davisthomas |
