ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64
#41
The first post is saying that the beetle-psx as been added.
So is it possible to change the resolution and have something better, close to pc result ?
#42
@Gaëtan - first and most importantly, welcome to the community!
i would always recommend the pine store for purchases, but admittedly Amazon also has some good deals Wink
As for beetle-psx, it's a retroarch core so explore the in-game menu a bit and there are some resolution settings, but the optimal resolution for these emulators is 720p and so we have set that as the max for retroarch.
#43
(08-29-2018, 06:56 PM)Mrfixit2001 Wrote: Thank you for your reply ! I'll see to pouchase one soon.
Than, for psx graphics it should be better than on pi3 ?
Could you tell if there will be new beta update soon ?
Also  I'm really curious about the performance on dc and psp emulation comparing to Rpi3.
I saw 4do emulator  so the 3do is supported ?
Sorry to bother you with questions, I'm more and more interested in that board Smile
#44
What game would you like to see tested? if I have it I will fire it up and report back.
#45
(09-02-2018, 05:31 PM)Brainy142 Wrote: What game would you like to see tested? if I have it I will fire it up and report back.
Thank you Brainy !
On DC, it would be good to test Dead Or Alive that is really borderline on pi3b and b+ and daytona usa.
On psp you could try tekken 6 and wipeout  with default settings and pspx2. If you have other games you could test it too Smile
#46
Question
Hi guys...
Unfortunately with the starting of the school my time to play (I mean not playing to video games  Rolleyes ) with the board has been dramatically reduced...
So now I discovered there are two releases on MrFixit Github page and I am quite confused:
Which are the difference? I don't use Kodi (I deactivated it )since the moment I use OSMC in another board, is the Rockbox version lighter?
Thanks!
#47
(09-03-2018, 11:17 AM)Danielsan Wrote: Hi guys...
Thanks!
While they use the same chipset Rockbox is not rock64 so if you have a rock64 you should use the image labeled rock64 to avoid incompatibilities...
#48
Oh my... What a dumb... I was convinced that Rockbox was like a software mediaplayer...
Got it, I'll stick with Recalbox for Rock64... Big Grin
#49
Thank you Brainy !
Tekken 6 is unplayable - 20fps or so, even with an overclock. Don't have the other games on hand.
[edit] with some tweaks and 1xPSP as well as Frameskip=1 its playable
#50
Thank you Brainy !
Here is a screenshot of Tekken 6 running on a pi3B overclocked at 1300mhz.
All ppsspp setting by default, except it's 2xPSP
[Image: 1536136942-tekken-6.png]
To compare the results, once in game choose "Practice" and then the "LARS" character
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,498 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,103 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 97,537 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,121 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,628 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,615 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,999 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,180 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,073 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 118,452 09-01-2024, 06:05 AM
Last Post: RaymondDay
