Clusterboard issue: onboard leds off / no boot
Ok, UART adapter it's arrived today.
Following THIS schema i connected
GND on pin 9
TX on pin 11
RX on pin 12
Which Armbian version is preferred to use now?
https://storage.googleapis.com/pine64-im....33.img.xz
This is one I built that has the networking fix already included.
Still waiting for it to make it into master in armbian build repo.
In the last few days i made some tests with the same expected results..
1° test: only one module in the clusterboard to test the module and the sd card.
Boot perfectly, i tested all modules on all slots and they works fine.
2° test: all modules on the board.
Module on slot #2 and #4 doesn't boot up. During the fist seconds on the screen i can see some caracters but it seems that the board stop trasmitting data.
The "rx" led on UART module stop blinking and i never car reach the login line.
On all the others slot after the same characters i can reach the login line.
The leds on usb side on slot from 1 to 4 are stationary on, the others are off
[Image: tRZKR6q.jpg]
[Image: RVm8igO.jpg]
[Image: C1sGafP.jpg]
On all the other slots the boot work fine
[Image: X0kVIez.jpg]
So, what tests can i do now?
  Managed Ethernet switch on the Clusterboard dsimic 6 16,985 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,644 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,577 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 28,461 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 12,310 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,685 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,744 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 7,044 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,628 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 10,962 08-15-2020, 07:31 AM
Last Post: poVoq
