Clusterboard issue: onboard leds off / no boot
Hi all!
today i started my clusterboard project but i found the first big problem.
i flashed the memory card with Armbian image, put the Sopine module in his riser, turned the clusterboard on and nothig happens. Confused
All the led near the riser never turns on, the RJ45 leds sometimes blinks for less than a second, but nothig appear connected to my switchport.
The only turned on led is the one on the sopine module..
Is this happened to someone else?
the img that i'm using is Armbian_5.41_Pine64so_Ubuntu_xenial_next_4.14.20.img (working perfectly on LTE board)
tried all the sopine modules with the same result.
Thanks to everyone for help
[Image: KF5jbno.jpg]
Are you using the fixed Armbian image that I uploaded? Or just the one on Armbian's site?
I've partially fixed the problem.. the clusterboard "works" only with an ATX psu, but anyway i'm still having many problems.
I've tried in order:
Armbian_5.41_Pine64so_Ubuntu_xenial_next_4.14.33
Build 5.35 from Pine64 Installer
No more than 3 sopine modules works toghether, with 4 no boot at all.
Do you perchance happen to have a uart/serial hookups?
what do you mean sorry?
i know what uart is but i don't understand your question.
(05-10-2018, 04:41 PM)Mark88 Wrote: what do you mean sorry?
I think they meant did you have one of these...
https://www.pine64.org/?product=padi-serial-console
Sorry I can't see/read, something like that or the below:
https://www.amazon.com/ADAFRUIT-INDUSTRI...art+to+usb
And before you ask why... it's because with out it, you can't debug what the heck is going on with the board! Blush
With it you, may be able to glean from the bootup messages what is happening... and we might be better able to understand things like 'no boot at all' ("well, it actually does power up, but it doesn't boot" or "the module power light just flashed when I had more than three plugged in and didn't do anything at all" or "the module does boot, but the darn things all claim they have the same mac address, so my router has a hissy fit", etc, etc).
Basically, without some way of connecting to that serial console, it's hard to debug stuff on ARM based SBCs as there is no BIOS, so no stuff to screen until the system is well and truly loading.
Thank you very much for your clear explanation!
i i'll give you more detailed info about the problem in few days
are both ok?
CH340G
https://www.amazon.it/gp/product/B01DC0D...85L5Z6&psc
CP2102
https://www.amazon.it/gp/product/B072K3Z...POXEHY&psc
(05-11-2018, 03:27 PM)Mark88 Wrote: i'll give you more detailed info about the problem in few days
are both ok?
No worries...
I would personally recommend the CH340G as I have had very little trouble with that particular USB to serial chipset. There is nothing wrong with the CP2102 either though, although it should only be able to do 1Mb baud rate instead of the needed 1.5Mb...
Note that you'll want some linking wires if you don't already have any... just the three... for GND, TX and RX.
  Managed Ethernet switch on the Clusterboard dsimic 6 17,553 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 15,065 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,790 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 29,288 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 12,728 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,847 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 36,307 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 7,250 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 15,026 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 11,261 08-15-2020, 07:31 AM
Last Post: poVoq
