First Attempt: No Boot
Sad
Hi All,
 I purchased the original Pine Board along with Pine's 64GB Micro SD Card, the battery and the display. I waited a very long time for the back-ordered White Pine Box and finally received it and set it aside. I recently started to assemble it and used the Pine (Etcher) software to download and flash the Android 6.1 OS that's supposed to be compatible with the touchscreen. It took a couple of attempts but I was able to flash the OS and put the card in the board.  When I Powered it up nothing happens but a red LED lights inside the box.
Any Ideas?? Huh
Any help is appreciated, Thank you,
Tom
it will probably be a good idea to use the battery and a power supply for a while until the battery becomes fully charged.
(10-24-2017, 04:55 PM)dkryder Wrote: it will probably be a good idea to use the battery and a power supply for a while until the battery becomes fully charged.
Thank you for the reply.
  I didn't have the battery in yet; just plugged in the power supply. Huh
Any other ideas?
Thank you.....Tom
Any other ideas?
Thank you.....Tom
Tom,
Which image did you download exactly using the installer utility ? did you connect the LCD correctly ?
This is one of those things that is easiest to troubleshoot in the IRC - so do join and try to get hold of me or someone else.
Any other ideas?
Thank you.....Tom
Tom,
  Star64: All listed distros don't boot tantamount 0 1,281 05-08-2026, 08:56 AM
Last Post: tantamount
Sad PINETAB-V doesn't boot. FEC 1 4,130 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 7,081 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,739 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 4,139 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 5,059 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 3,609 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  How to boot from SD card on pinebook pro linux123 3 10,612 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 5,801 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 3,863 10-18-2020, 01:41 PM
Last Post: toiny
