Bad EMMC
#21
1- boot stable version from sd card using pine installer.
2- sudo ./pine64_update_kernel.sh 0.7.19
sudo ./pine64_update_uboot.sh 0.7.19
sudo ./pine64_update_package.sh 0.7.19
3- reboot
4- pine64_install_to_emmc.sh xenial-mate 0.7.19
I find the yellow brick path to OZ :-P
#22
(10-16-2017, 01:59 AM)ayufan Wrote: Thanks jbk on helping to figure out how we should fix that Smile
Once you run Pinebook, try to edit `/boot/uEnv.txt` and enable `emmc_compat=150mhz` mode which bumps the eMMC performance from usual 80MB/s to around 120MB/s.
This fix also helps with 16GB/32GB performance.
I tried 150 MHz and it is faster, from about 75 to more than 100 MB/s. Can I try 200 Mhz on stock eMMc?
#23
You can try, but it didn't work for me stable.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
#24
It does not boot with this settings, it does not go after initial Pinebook logo.
It does not recognize other values except 150 and 200?
#25
Nope. The default is 100MHz, and on Pinebook it seems that 150MHz is working correctly.
Releases:
Buy me a Beer
#26
(10-17-2017, 02:55 AM)erchache2000 Wrote: 1- boot stable version from sd card using pine installer.
3- reboot
hello erchache2000 i have the same problem with the emmc64Gb and I am not able to install the OS on it. I boot with SD and Pinebook tells me that it does not detect the emmc, I have tried with the old 16Gb and it works perfectly. Could you help me?
Thank you.
#27
3- reboot
Thank you.
This issue has been resolved on new OS build release. The new eMMC module is 5.1 type and not recognize by old OS build. Please using PINE64 installer download new OS build and retry again.
#28
There is no way to keep existing i3 setup and all packages what I installed to move to new emmc module?
Sign to my Telegram channel ❤️
#29
3- reboot
Thank you.
You need to boot from SD card, and upgrade SD card before install to emmc.
SD card has stable version and you need to upgrade to 0.7.19 to get emmc correctly.
#30
3- reboot
Thank you.
Thanks a lot!!! I also see the light!!!!
  eMMC compatible with Pinebook leperotero 0 4,275 07-19-2022, 07:15 AM
Last Post: leperotero
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,826 06-07-2022, 10:35 PM
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 4,444 10-16-2021, 02:03 PM
Last Post: quixote
  How to write image to emmc module on the pinebook eclay 16 51,755 06-11-2020, 03:03 PM
Last Post: jezek
  EU Shop for spare parts/eMMC? Noxmiles 4 9,442 07-05-2019, 03:16 PM
Last Post: soupbowl
  how to install emmc in just arrived pinebook dkebler 11 34,178 06-13-2019, 01:13 AM
Last Post: zk1sps
  eMMC replacement problems. frank-zappa 3 7,860 01-08-2019, 04:35 AM
Last Post: frank-zappa
  Bad eMMC? sundog 2 6,770 11-20-2018, 09:37 AM
Last Post: sundog
  Pinebook accessories (emmc usb card) RockPro64Newbie 0 3,440 09-11-2018, 07:19 PM
Last Post: RockPro64Newbie
  emmc upgrade Erik 1 5,485 10-23-2017, 08:17 AM
Last Post: erchache2000
