Bad EMMC
"Are you talking about to create my own installer with this patch? ;(
Will be patched in the next installer release?"
It's more a way of replacing parts of an existing install so that they work with the 64G sandisk module. The kernel just needs copying the new image into /boot and linking it to /boot/Image. Unfortunately updating the uboot executable is a bit more complicated and needs the dd command as shown in the script. Agreed it would be a lot easier if there was an install image that incorporated the changes. That will happen eventually, it's just a question of time to finalise the changes and then getting them to ayufan and/or the Armbian team. The main thing is that supporting the new cards is possible.
(10-10-2017, 05:02 AM)jbk Wrote: "Are you talking about to create my own installer with this patch? ;(
I received a email support that says sandisk emmc module will be patched to pinebook on the next two weeks :-P
Sandisk is only supported for Rock64 at the moment.
(10-12-2017, 02:02 AM)erchache2000 Wrote: I received a email support that says sandisk emmc module will be patched to pinebook on the next two weeks :-P
Excellent, that should be easier than messing around with my kernel/uboot Smile
The Sandisk eMMC module on Pinebook already works and thanks to ayufan.
Please download build 0.7.19 from build ayufan github 0.7.19 and boot from SD.
Using terminal and issue follow command:
sudo install_to_emmc.sh xenial-mate 0.7.19
Thanks jbk on helping to figure out how we should fix that Smile
Once you run Pinebook, try to edit `/boot/uEnv.txt` and enable `emmc_compat=150mhz` mode which bumps the eMMC performance from usual 80MB/s to around 120MB/s.
This fix also helps with 16GB/32GB performance.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
Thanks for the mention Ayufan Smile
Hacking things around for testing like I did is one thing, but having the discipline to provide changes in a way that others can benefit from is a whole lot more work. You have my respect! Congrats and thanks on getting this fixed.
As a new open source platform, Pinebook development is an ongoing process and represents a great opportunity to get involved with computing on a different level
(10-16-2017, 06:34 AM)jbk Wrote: Thanks for the mention Ayufan Smile
Thanks, jbk. Your beer is on me.
#19
(10-16-2017, 01:59 AM)ayufan Wrote: Thanks jbk on helping to figure out how we should fix that Smile
Thanks a lot for your time and work.
I’ll try tomorrow Wink
#20
I tried this https://github.com/ayufan-pine64/linux-b...118.img.xz
and pinebooks don't boot from sd ;(
I used pine64 installer to flash it.
I think I don't have idea to do it correctly ;(
  eMMC compatible with Pinebook leperotero 0 4,365 07-19-2022, 07:15 AM
Last Post: leperotero
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,992 06-07-2022, 10:35 PM
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 4,548 10-16-2021, 02:03 PM
Last Post: quixote
  How to write image to emmc module on the pinebook eclay 16 52,617 06-11-2020, 03:03 PM
Last Post: jezek
  EU Shop for spare parts/eMMC? Noxmiles 4 9,554 07-05-2019, 03:16 PM
Last Post: soupbowl
  how to install emmc in just arrived pinebook dkebler 11 34,540 06-13-2019, 01:13 AM
Last Post: zk1sps
  eMMC replacement problems. frank-zappa 3 7,963 01-08-2019, 04:35 AM
Last Post: frank-zappa
  Bad eMMC? sundog 2 6,871 11-20-2018, 09:37 AM
Last Post: sundog
  Pinebook accessories (emmc usb card) RockPro64Newbie 0 3,505 09-11-2018, 07:19 PM
Last Post: RockPro64Newbie
  emmc upgrade Erik 1 5,554 10-23-2017, 08:17 AM
Last Post: erchache2000
