Cigar Box Enclosure
I think I am going to try to make one out of a nice cigar box, and thought about a fake hollow book. I want to use mine as a set top box for the TV so I want it to blend in and not stand out.
A retro look.  The non-computer.  I'll figure out some way to route the wires so you can't see them.  The TV is already inconspicuous.
I have not identified the box yet, so many to chose from.
Will I be able to use Logitech Living-Room Keyboard K410 ???
(03-08-2016, 08:45 AM)dockle Wrote: I think I am going to try to make one out of a nice cigar box, and thought about a fake hollow book. I want to use mine as a set top box for the TV so I want it to blend in and not stand out.
Yes, that keyboard should work fine.
I like your idea of making a case out of a cigar box or hollow book.
I am going to use a hollowed out book.  It is sitting ready for the board to go in.  Still haven't fully worked out the cables yet though. I am a little concerned about ventilation and possible overheating though. Any suggestions?
For ventilation, i would suggest getting a couple small fans, one to blow onto the Pine, and another to push air out of the book, probably through some loose pages. I'm not sure what the book looks like, or how big, but basically you want air to get the heat off the board, then push that hot air out of the book. Maybe a small slot on one side (for cables as well!) could serve for ventilation.
If I've helped you with something, please leave a rating for my responses.
(03-10-2016, 11:44 AM)pine.tree Wrote: For ventilation, i would suggest getting a couple small fans
I would suggest relying on real measurements instead of assumptions. This thread might be worth a read (the next days also): http://forum.pine64.org/showthread.php?t...37#pid3337
I wasn't aware of the actual data, but for my project I'm using two 80mm fans connecting with a USB, with a speed controller inline.
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,682 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,502 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,526 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,910 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,919 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,170 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,142 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 31,605 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,630 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 10,494 10-13-2016, 08:47 AM
Last Post: Bluphire
