Kernel Panic on Rock64 linux
Ok,Thank you!
I also get kernel panics on every distribution I tried (and I tried nearly all), I tried two different SD cards (only have two).
I could get to run an Android build though. I checked for solder bridges but I coudn't find any. Anything else I can try? (I have the 4gb model)
Try different SD card, it is likely that your SD is just broken.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
getting the same error. Rock64 4gig version. Multiple memory cards, multiple build OSes Angry
(09-01-2017, 07:45 AM)polartx Wrote: getting the same error. Rock64 4gig version. Multiple memory cards, multiple build OSes Angry
Please check whether stock Android build also has the memory crash issue. If still getting Kernel Panic, please file a support ticket at support.pine64.org
I saw a kernel panic w/ xenial-minimal-rock64-0.4.17-85-arm64.img after I unplugged a USB 3.0 hard disk (nothing was mounted on it).  Seems like the OS thought it was still connected.
[ 7800.498794] INFO: task parted:5470 blocked for more than 120 seconds.
[ 7800.499779]       Not tainted 4.4.70-rockchip-ayufan-85 #1
[ 7800.500569] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 7800.502124] Kernel panic - not syncing: hung_task: blocked tasks
[ 7800.502998] CPU: 3 PID: 29 Comm: khungtaskd Not tainted 4.4.70-rockchip-ayufan-85 #1
[ 7800.504105] Hardware name: PINE64 ROCK64 (DT)
Playing with jessie-minimal-rock64-0.5.7-101-arm64.img now, and don't see the same issue.  It does take several seconds for it to decide the USB device is no longer available when I unplugged the cable.  Nothing was active when the cable was unplugged, it just spewed the following to the console :
[  873.393783] usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
[  873.394805] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  873.395754] usb usb5-port1: cannot disable (err = -32)
[  875.910788] usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
[  875.911801] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  875.912735] usb usb5-port1: cannot disable (err = -32)
[  878.426774] usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
[  878.427787] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  878.428729] usb usb5-port1: cannot disable (err = -32)
[  880.943791] usb usb5-port1: Cannot enable. Maybe the USB cable is bad?
[  880.944809] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  880.945741] usb usb5-port1: cannot disable (err = -32)
[  880.946543] xhci-hcd xhci-hcd.8.auto: Cannot set link state.
[  880.947492] usb usb5-port1: cannot disable (err = -32)
[  880.948328] scsi host0: uas_post_reset: alloc streams error -19 after reset
[  880.952607] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Edit: Looks like the latest jessie minimal also panics after disconnecting USB 3.0 device. Filed a issue on github, with ayufan (not sure if it was the right project page though).
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,767 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,599 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 30,158 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,609 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,932 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,201 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,523 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,500 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,912 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,256 11-28-2022, 02:18 PM
Last Post: Macgyver
