Rock64 v2.0 u-boot SPI issues
I've some rock64 V2.0 boards . All of them flashed SPI u-boot long time ago with Ayufan script. They worked flawlessly until now that i've tried to update to debian 13. No way to boot installer neither sd card or usb i had to erase spi u-boot to be able boot debian 13 installer. Now i've installed debian 13 but no way to burn any working SPI u-boot. The last ones dont do nothing, any output from serial console and older ones dont let boot debian 13 from sd card with a kernel panic message show in serial console.
I guess there is some issue with SPI u-boot and rock64 V2.0.  Any working updated SPI u-boot in rock64 v2.0 available?
Thanks in avance
Flashing and Erasing the SPI
Traditionally, booting Linux on the ROCK64 required an eMMC or microSD card, however it is now possible to boot without those, assuming the SPI memory has been flashed. The ROCK64 contains an onboard 128Mbit SPI flash memory, which can be flashed with U-Boot in order to provide additional boot options:
USB2 / USB3 drive
PXE
microSD
eMMC
1. Write the U-Boot image
Download the latest u-boot-flash-spi.img.xz image
Write it to a microSD card using dd or Etcher
# From Linux or macOS
xz -k -d -c -v -T 3 u-boot-flash-spi.img.xz | dd of=/dev/<sdcard> bs=1M
Make sure you write to the correction location, it will destroy all data.
https://github.com/ayufan-rock64/linux-b...ash-spi.md
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,610 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 30,198 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,631 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,961 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,216 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 6,337 02-29-2024, 02:12 PM
Last Post: reukiodo
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,535 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,512 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,929 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,267 11-28-2022, 02:18 PM
Last Post: Macgyver
