Does the ROCK64 use any closed source boot loaders, firmware, drivers or other blobs?
Does the ROCK64 use any closed source boot loaders, firmware, drivers or other non-open blobs?
If so, how many and for which components?  Thanks!
What I saw so far is a first stage loader that is a binary (check https://github.com/ayufan-rock64/rkbin/tree/master/rk33 or RK's upstream) and of course ARM Mali. As boot0 in the case of Allwinner this loader initializes DRAM and then hands off to u-boot. RK has released u-boot spl as a replacement for this loader for RK3399 and RK3288, RK3368, so we should get a u-boot spl for RK3328 at some point. Otherwise you can check out their BSP sources at https://github.com/rockchip-linux
Okay, so to summarize @xalius's above post, we have:
Boot requires:
first stage boot loader (closed blob) -> u-boot (closed blob) -> Linux kernel (open)
However, this might improve to:
first stage boot loader (closed blob) ->  u-boot spl for RK3328 (open?) -> Linux kernel (open)
(Aside: According to info at https://github.com/rockchip-linux/u-boot, it looks like "spl" stands for secondary program loader.)
Also, the using ARM Mali GPU requires a closed blob driver.  For all HDMI output?  Or just for 2D and/or 3D hardware acceleration?
Is the network driver open?
Thanks!
first stage loader is closed, uboot is open
spl will in the future replace first stage loader
Mali is needed only for 3D acceleration, there's no 2D acceleration.
HDMI is driven by open source drivers. Kernel configures DW HDMI registers and maps memory where the FB is stored to be render by HDMI controller. The same FB is used by Mali to render 3D content. AFAIK all the rest codes to handle VPU are open.
So, closed blobs are:
- first stage loader with DRAM init code,
- MALI driver,
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
are wifi and ethernet open or just drivers from the chip maker? it is hard for me to figure out what is going on in
https://github.com/ayufan-rock64/rkbin/t...mware/wifi
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,978 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,446 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,242 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,225 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,846 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,853 11-03-2025, 09:25 AM
Last Post: darkfader
  PXE Boot example? lewis 7 18,644 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  can rock64 4gb ram run entirely on free software? heocb 1 4,119 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,326 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  How to boot an older, working kernel bits 0 3,182 11-01-2024, 04:43 PM
Last Post: bits
