How to boot an older, working kernel
Earlier this year, there was an update to the Linux kernel that broke booting Rock64 from their eMMC and it was necessary to force using an older, working kernel version.  It's since been fixed, but in case there is again a need to boot with a kernel older than the latest, here's one way:
Drop a file in /etc/flash-kernel/ubootenv.d that forces the U-Boot environment variable fk_kvers to a working kernel version present in your /boot, then run flash-kernel to regenerate the U-Boot bootscript /boot/boot.scr
echo "env set fk_kvers 6.1.0-22-arm64" > /etc/flash-kernel/ubootenv.d/90-force-kernel-version &&
flash-kernel
When you want to stop forcing the kernel version, remove /etc/flash-kernel/ubootenv.d/90-force-kernel-version, run flash-kernel, and reboot
This works because flash-kernel rebuilds /boot/boot.scr from the template /etc/flash-kernel/bootscript/bootscr.uboot-generic, and this includes "@@UBOOT_ENV_EXTRA@@", which gets replaced by the contents of each of the files in /etc/flash-kernel/ubootenv.d/ and the boot script boots the referenced kernel
  PXE Boot example? lewis 7 18,519 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  problem with debian emmc boot G4zCDzWb 10 31,051 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 5,125 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 3,465 12-27-2023, 10:34 AM
Last Post: dstallmo
  Disabling last mount time check on boot acwest 0 2,385 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 14,182 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,931 06-27-2022, 06:52 PM
Sad Blinkind red LED and stop working randomly ? jean_bruder 1 4,150 12-12-2021, 07:35 PM
Last Post: Rocklobster
  Linux 5.15 Kernel - openSuse mark1250 0 3,071 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,751 10-22-2021, 05:45 AM
Last Post: kwinz
