Android 6.0 Tablet and TV (release candidate, maintained)
Thanks for the idea Fro$t. I installed it on my phone but to pair it with my Pine don't I need a pair code which would require me using a mouse on my Pine to obtain?
Can anyone help me get my Pine up and working with Android where my mouse works?
I haven't been able to use it for quit a while.
bob, if you are not using it most likely it is because you do not want to. this is what you said in early april,
"Both the HDMI switch and the Logitech mouse work correctly on the Pine using Android versions jenkins-android-tv-5.1-pine-a64-14 and android-7.0-pine-a64-14"
Right. And then I tried to upgrade to Android v 6.0 and my mouse no longer works which means I can't use my Pine.
I had overwritten the version of Android 5.1 on my SD card where my mouse worked so I can't go back to the working version.
I still need help getting my Pine working with a version of Android and my mouse working.
Where is this uEnv.txt file located? There is no such file on any of the file systems in the partitions from this image http://files.pine64.org/os/android/andro...2GB.img.gz and it does not seem to apply 1080p60 resolution settings if you do create a uEnv.txt file in the partition marked as bootable. I am trying to get the PINE64 2GB to output in 1080p on Android.
You have to use this Android build: https://github.com/ayufan-pine64/android-6.0/releases. The official releases doesn't support that.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
There is a bug with the uEnv.txt file in the android tv 6.0.1 you can't change the resolution from the uEnv.txt file.
I have emailed ayufan for the bug
Gesendet von meinem SM-T580 mit Tapatalk
(05-06-2017, 08:47 AM)LavosPhoenix Wrote: Where is this uEnv.txt file located? There is no such file on any of the file systems in the partitions from this image http://files.pine64.org/os/android/andro...2GB.img.gz and it does not seem to apply 1080p60 resolution settings if you do create a uEnv.txt file in the partition marked as bootable. I am trying to get the PINE64 2GB to output in 1080p on Android.
I also was trying it with the uEnv.txt file but it didnt work i contacted ayufan and he said to me that it is a bug.
sfatlind09: please try this latest build: https://github.com/ayufan-pine64/android.../tag/0.3.5
Releases:
Buy me a Beer
Do you make later when android oxygen comes out official builds for the pine ?
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,870 08-20-2026, 08:45 AM
Last Post: ahegarosib97
Shocked Remote for Android? liodra 18 50,826 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,415 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,880 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,491 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,759 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,877 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 413,771 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,680 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 164,186 02-10-2019, 07:44 PM
Last Post: mmmarcus
