Switching boot source on SOPINE64
How will the selection of boot source be handled on the SOPINE64? I do not see a switch or jumper on the baseboard or module board to switch between a micro SD card and a eMMC card.
The boot source will be the SD card; the /rootfs can run from the eMMC.
The A64 will probe the mmc/spi interfaces in a set sequence, sdcard has priority over eMMC, so it depends where you have a valid boot0/spl loader. You can also install u-boot into the SPI flash and boot from network or USB for example. If no valid boot source is found, it will fall back into FEL bootloader mode which is communicating viat the USB OTG port. This can be used to upload u-boot for example and then boot or expose eMMC as USB mass storage...
boot-> check fel key pressed (yes)--> FEL mode (boot from USB OTG)                          \                        (no) \                            \-------> 1) try to boot from SMHC0 (SD card)                                      2) try to boot from SMHC2 (eMMC)                                      3) try to boot from SPI0 (SPI NOR Flash)                                      4) FEL mode (boot from USB OTG)
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 7,129 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,457 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,585 02-23-2021, 05:33 PM
Last Post: thedu
Exclamation Can't boot when SD card inserted kivox 5 13,614 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 6,141 11-29-2019, 04:39 AM
Last Post: evilbunny
  Pine A64 stuck in boot process joey 1 5,880 05-28-2019, 09:07 PM
Last Post: joey
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 10,377 02-22-2019, 03:25 AM
Last Post: GaryFunk
  boot loop with lcd plugged in drock 0 3,701 01-09-2019, 01:37 AM
Last Post: drock
  LED flashes for 1 second, board won't boot Audioslave 2 7,368 08-02-2018, 10:28 PM
  short boot time after power-up bongo 7 17,414 10-31-2017, 08:02 AM
Last Post: bongo
