5.25 V _ ... 2A Power USB Adapter
Is it safe to use 5.25V with 2A for Pine64+ ?
A64 - DB - 2G - Rev B
2016-03-21
(02-07-2017, 02:47 PM)Guest2000 Wrote: Is it safe to use 5.25V with 2A for Pine64+ ?
2016-03-21
5.25v would be pushing it...  I would not.
5.1v  @2.5A
2016-03-21
I routinely run my pine64s with 5.25v 4A power supplies (adjustable quad-USB 12v - 5v power supplies) to overcome voltage sag over the microUSB lead and connectors. It should not be an issue running the pine64 at this voltage as the PMU is spec'd with a maximum of 7v. Just be aware that your 5v and USB voltages may be a bit higher than 5.0v if that matters to you! 5.28v at the power supply drops to 5.22v at the pine64s USB ports and 5v pin (unloaded, 5.19 with a USB key plugged in) with a good microUSB power lead, and this is within the USB 5v power spec (5v + 0.25, -0.55/0.6 [depending on version]). This is with the DC/BAT jumper in the DC IN position! Wink
I take it you want to use something like the 5v (5.25v) power supplies that Adafruit sell for the Raspberry Pi?
i have no idea if it is safe, but for the past month i have been using one of these
https://www.amazon.com/gp/product/B00D7C...UTF8&psc=1
with one of these
https://www.amazon.com/gp/product/B01MQG...UTF8&psc=1
and my pine64 has not burned out yet.
i have the buck converter dialed in at 5.25V and it is a continuous 3A output. i am using this on my older board [7 months useage] which had shown signs of power related boot problems and those have stopped happening as often.
(02-09-2017, 01:55 AM)dkryder Wrote: i have no idea if it is safe, but for the past month i have been using one of these
with one of these
5.25V should be safe.
  New RockPro64 Power Up Problem enorbet2 7 13,603 10-28-2023, 12:08 PM
Last Post: dkebler
  USB adapter to eMMC module not recognized danril 0 3,186 11-25-2022, 04:16 AM
Last Post: danril
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,009 06-17-2021, 05:35 AM
Last Post: kqlnut
  Pinecil power Erincka 0 3,427 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,537 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,420 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 24,210 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,355 06-17-2020, 02:00 AM
Last Post: hanscees
  USB C hub and Ethernet adapter jaysistar 3 10,350 01-20-2020, 04:07 PM
Last Post: belfastraven
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,935 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
